Page 1 of 4 1234 LastLast
Results 1 to 12 of 45
Thread: NCPlot Final beta now available
    Gold Member MetLHead's Avatar
    Mar 2003
    This is it!! The last NCPlot beta is now available, and the release of NCPlot v2.00 has been scheduled for March 1st! The pre-release pricing offer will expire at release, so take advantage of it while you still can...
    Download NCPlot at:
    www.ncplot.com
    NCPlot v2.0 Release Candidate 4 Release Notes
    January 27, 2007
    Bug Fixes
    NCPlot would crash on startup if the scripting engine could not be started. This is fixed.
    Canned cycles were resetting the active feedrate if no "F" word was commanded on the canned cycle block. This was causing incorrect warning messages when the feedrate check warning is enabled.
    The G09 command was causing NCPlot to ignore the corresponding motion command. This is fixed.
    General
    Added the tool "Jump to Line Number" to the Edit menu. This tool will prompt for a file line number and then move the cursor to the entered line. Note that this will be the *file* line number and not the "N" block number.
    Adding the ability to read "SPLINE" objects when importing DXF drawings. This is not finished, it currently only creates a polyline through the control points.
    Keep in mind that development will continue with the release of periodic updates after release. So if you've requested a feature and it's not in for the release version, that doesn't mean it's not going to make it, it just means I haven't managed to work it in yet.
    Thanks,
    Scott
    Moderator tobyaxis's Avatar
    Jan 2006
    Scott,
    I just purchased a V2 License today. LOL, it only took a year to finally buy it, but well worth every penny
    Thanks for the great Program.
    Cheers
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Mar 2003
    Thanks Toby! I knew you'd get around to it eventually
    Scott
    Jan 2006
    Quote Originally Posted by MetLHead View Post
    Scott
    A year is just plain LAZYNESS
    BTW: How about for your next Version a 6 Axis Lathe with Live tools.
    PM me if you want the Machine Configurations. I'll get some stuff together and send it to you. I hope you have a LARGE EMAIL BOX, LOL
    Toby D.
    Schwarzwald
    Jan 2005
    SoCal
    Thanks Scott for an excellent program with SUPER support.
    It has paid for itself many times over in saving material, time and (unbroken) tool bits.
    Jan 2006
    Red face Ooops!!!!!!!
    Ok Scott,
    Ditch the first Drawing. There were a few mistakes that had to be corrected. You should get the next one in a few minutes.
    Toby D.
    Schwarzwald
    Mar 2003
    Pres,
    Thanks! I like to hear that everything's going well!
    Toby,
    Yep, I got your drawing.
    Thanks,
    Scott
    Jul 2005
    z axis question
    From the outset it looks like ncplot is awesome. I am using Rhino V3 but I will V4 tomorrow. I want to use TurboCNC with Rhino but I couldn't find a good conversion program, until now.
    I will be making wax rings for casting but when I convert the ring using ncplot my Z axis is set to zero. I have read the ncplot tutorials but can't figure this one out. Please tell me that I don't have manually put in the Z axis because some of my designs are very complex.
    So.....why does my z axis always set to zero? Am I doing something wrong?
    Thanx in advance for any help!
    -=7ofclubs=-
    -=sHrEk=-
    Mar 2003
    The DXF importing in NCPlot is designed mainly for creating 2.5D G-Code. It reads the drawing layers in and lets you set the machining parameters for each layer. It does not read the Z axis depths from the drawing. At one time I had thought about doing this, but it seemed to work well the way it was. If you have a drawing you can send me, I can re-look at doing this.
    Thanks,
    Scott
    Jul 2005
    ring example
    Scott, you are totally awesome, thanx for considering it.
    What I have done is made a small CNC machine. I don't have a Y table because I will use it as an axis to make the rings. Some of the ring designs I have are fairly complicated and it would be impossible, not to mention time consuming, for me to figure out the Z settings for each cut.
    As I stated before some of my designs are fairly complicated and use celtic knots, skulls, ring settings. One thing I am working on now are Indian spin rings. The spin ring is actually two rings, one fit inside the other, so that the outside ring spins around the bottom ring.
    If you could help me out with this you have an instant customer.
    Attached is a fairly simple spin ring in .dwf format.
    -=wEsLeY=-
    Attached Files Attached Files
    -=sHrEk=-
    Mar 2003
    Hi Wesley,
    I looked at the drawing you attached, and it appears to be a 3D mesh of your part. Since NCPlot is not a CAD/CAM system, it will only create G-Code from drawings that already represent the toolpath. I don't think that it will do what you need from a drawing like this, I think you should be looking at a CAM program to do this.
    Thanks,
    Scott
    Jul 2005
    Thanx
    Thanxs Scott,
    I appreciate your time, can you recommend a good, cheap, CAM program?
    -=wEsLeY=-
    -=sHrEk=-
  • Page 1 of 4 1234 LastLast
    1. NCPlot v2 beta 11 now available
      By MetLHead in forum NCPlot G-Code editor / backplotter
      Last Post: 10-02-2007, 10:54 AM
    2. NCPlot v2 beta 10 now available
      Last Post: 07-23-2005, 08:11 PM
    3. NCPlot v2 Beta 9
      Last Post: 06-29-2005, 09:16 PM
    4. NCPlot v2 Beta 8
      Last Post: 06-13-2005, 08:43 PM
    5. NCPlot v2 Beta 7
      Last Post: 06-09-2005, 06:41 PM
