| NCPlot G-Code editor / backplotter Discuss NCPlot software here. |
Hi again, Try this program snippet in NCPlot. If you make the 'A' value zero the plot works fine, but if you run it like this at A-90.0 plotting is doing funny things. Please help % O4825 G56 G00 X-450.0 Y230.0 G01 A-90.0 F5000 (M12 THREADTOOL STATION 4) (NOTE CUTTER RAD TO BE SET AT 4.35) T4M6 G0G17G90X0.Y50.S2744M3 G43Z10.H4 Z2. G1 Z-18.0 F500 G91 G41 D4 X1.075 Y-4.989 F93 G3 X4.989 Y4.989 Z0.378 R4.989 G3 X0 Y0 Z1.750 I-6.063 J0 F320 G3 X-4.989 Y4.989 Z0.378 R4.989 G1 G40 X-1.075 Y-4.989 G90 G0 Z10.0 Y-50. G1 Z-18.0 F500 G91 G41 D4 X1.075 Y-4.989 F93 G3 X4.989 Y4.989 Z0.378 R4.989 G3 X0 Y0 Z1.750 I-6.063 J0 F320 G3 X-4.989 Y4.989 Z0.378 R4.989 G1 G40 X-1.075 Y-4.989 G90 G0 Z10.0 Z150. M1 X-450.0 Y230.0 M30 % Thanks ...Turner |
| Hi Scott, Ive had a play around with NCPlot and found you were right G19 is plotting correctly, didnt think you would miss something like that. The problem was in the G/M Codes part of the configuration M87 mirror image. Our machine uses M86/M87 for Clamping its fixture its a twin pallet daewoo, so i deleted M87/M88 out of the config and all plots well now ![]() Turner. |
| Turner, Yes, that makes sense, the mirror image would make your arcs appear backwards. Thanks for letting me know how you fixed this! By the way, I found and fixed the problem with the helical arcs not plotting correctly with the 4th axis. This will be in the next update. Thanks, Scott |
