Results 1 to 3 of 3
Thread: Run Time Estimator
    Oct 2007
    Run Time Estimator
    Scott ,
    I'm trying to get a better estimate on run time and ran into a problem
    if a file has more than 256 tool changes i get a plot geometry error
    i have configured as follows set sub routine to look for sub set tool change on
    M06 than made two subs - (m06 m99) to act as a laser pierce and than
    (f135 m99) to set cut feed rate. All works fine if program is 256 or less sub calls. I have also tried t code as well and same thing is there a work around or is this a memory issue. when i get this error disabling m06 or set to ignore sub lets it plot fine.
    thanks
    ps tried this in both v2.21. and v2.23
    Gold Member MetLHead's Avatar
    Mar 2003
    This is a limitation within NCPlot. The data type used to store the tool change number is only a byte wide. This was to minimize the memory required to store the backplot but means that it can't store more than 256 tool changes. This seemed like more than enough when I set the data type....
    I'll change the data type to allow more tool changes.
    Thanks,
    Scott
    Oct 2007
    ok thanks i'll watch for the next version
  1. Machining Calculator & Estimator
    By mrainey in forum Product and Manufacturer Announcements
    Last Post: 10-11-2012, 12:37 AM
  2. Replies: 0
    Last Post: 04-24-2012, 08:46 AM
  3. Job Opening Manufacturing Cost Estimator (Illinois)
    By mkim@dynomaxinc in forum Employment Opportunity
    Last Post: 12-19-2011, 03:56 PM
  4. Introducing | Project Estimator by Optimation
    By bfoulk in forum Product and Manufacturer Announcements
    Last Post: 10-11-2011, 09:17 AM
  5. Building my shop, Found out that I'm not a good estimator.
    By trilect in forum CNCzone Club House
    Last Post: 05-15-2005, 10:17 PM
