Results 1 to 3 of 3
Thread: First tool not listed and G28 U0 W0 not correct
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    two other possible bugs? see pic attached.
    this is a very simple warm-up program.
    problem 1 is the first tool is not listed in the tool list on the left?
    the program was typed in by hand and plotted a few times. only 1 tool showed.
    however after saving and re-loading the program it showed both tools so the
    problem seems intermittent?
    problem 2 is G28 U0 W0 is moving the tool in rapid to X0 Z0.
    It should move in the opposite direction and go home directly.
    To make this work you may need to set where 'home' is.
    That could be added to the machine configuration as.....
    Maximum Travel X = 300.0
    Maximum Travel Z = 1000.0
    then on reading a G28 U0 W0 it rapids to home at X300.0 Z1000.0. Or something
    Attached Thumbnails Attached Thumbnails First tool not listed and G28 U0 W0 not correct-g28u0w0.jpg
    Gold Member MetLHead's Avatar
    Mar 2003
    I tried it here and confirmed that the first tool is not showing up in the tool list, don't know what's going there yet.
    To have motion back to home position show up correctly you should set the work offsets in the machine configuration. Go to "Setup / Machine Configuration" then click the "Work Offsets" page. Set X and Z values for the G54 (or whatever offsets you use). You can then use the menu "Draw / Axis Lines" to set where the zero lines are displayed.
    Thanks,
    Scott
    Aug 2011
    Fordaville
    hmmm. it kind of works *visually* but it's not the correct way as far as a real machine would do it.
    On a lathe the G54 X is always 0. Each tool has a geometry offset that sets the diameter. There is no need for an additional work offset to shift *ALL* of the tools an extra amount (i.e. basically a turret shift). S0 G54 X should always be 0 which does not fix the problem.
    See the pics.
    1st pic is with my real G54 workshift from the machine (X0 Z355.720)
    NCPlot thinks the machine zero is on the left of the part (not correct)
    2nd pic is with G54 X0 Z-355.720
    Now NCPlot puts the Z on the right side of the part (correct) but U0 still goes to X0
    However the G54 Z on the machine is really a positive number.
    3rd pic is with faked G54 X-250.0 Z-355.720
    Now NCPlot rapids the tool to the fake machine home but still displays 'X0 Z0'
    It *looks* ok and is usable like that but it isn't right.
    At least now the tool is not rapiding to the work X0 Z0 so OK I suppose that problem is solved
    Attached Thumbnails Attached Thumbnails First tool not listed and G28 U0 W0 not correct-g28u0w0_1.jpg   First tool not listed and G28 U0 W0 not correct-g28u0w0_2.jpg   First tool not listed and G28 U0 W0 not correct-g28u0w0_3.jpg
  1. Do you trust your end mill holders to keep the correct tool height?
    By beanbag in forum Tormach Personal CNC Mill
    Last Post: 12-05-2012, 03:15 AM
  2. Need Help!- How to measure correct tool offset specially in X axis for a DRILL in CNC LATHE
    By TS ENGG in forum Calibration and Measurement
    Last Post: 04-10-2010, 03:24 AM
  3. Need info on router listed in gallery
    By hsgreer in forum DIY CNC Router Table Machines
    Last Post: 11-05-2009, 03:49 AM
  4. Similar Threads listed
    By CNCadmin in forum CNCzone Site News and Contests
    Last Post: 01-10-2005, 11:25 AM
