Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 10-11-2011, 06:13 AM
TURNER is on a distinguished road
G66 PROBLEM
Hi Scott, hope you are well.
I may have found another problem. When using G66 modal sub call, ncp doesnt seem to work on arc moves. Please plot mocked up program to see problem. What this is for is, we do some drilling thru an extended bush around a turned boss so if we move linear the bush could collide with the boss. So i came up with the idea of arc moving around the part and drilling with a sub.
O1234
G21
G0Y74.5
X0
G66P7000
G2X73.37Y12.94R74.5F1000.
G3X71.49Y20.95R74.5F1000.
G3X68.75Y28.71R74.5F1000.
G3X65.16Y36.12R74.5F1000.
G3X60.27Y43.79R74.5F1000.
G3X54.49Y50.81R74.5F1000.
G3X47.89Y57.07R74.5F1000.
G3X40.58Y62.48R74.5F1000.
G3X32.66Y66.96R74.5F1000.
G3X24.26Y70.44R74.5F1000.
G3X15.49Y72.87R74.5F1000.
G3X6.49Y74.22R74.5F1000.
G67
M60
M30
O7000
G0Z10.0
G1Z-100.
G0Z10.
M99
I have tried this on a fanuc 18 and it does work as expected.
Thanks,
Keith.
Old 10-14-2011, 11:37 AM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Thanks Keith, I'll take a look at this.
Scott
daewoo puma 12lb tape format problem/parameter problem robb12877 Daewoo/Doosan 0 08-25-2011 12:13 AM
Surface finish problem - Could you please help me overcome this problem? DMBGO EMCO Lathe 5 08-04-2010 05:33 PM
machine problem or software problem? bcnc Syil Products 8 10-26-2009 09:51 AM
