Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 09-27-2011, 10:39 AM
Scott_M's Avatar
Scott_M is on a distinguished road
Mach3 lathe .prg files ?
Hi Guys
I have just recently started using NCPlot for Lathe work. I am running Mach Turn. I noticed that it was not displaying the G76 threading cycle properly and started reading. It appears that Mach uses a different format for G76.
In the G760.PRG file it refers to a 2 line format and all of the “Word” letters are different. Mach uses a single line format
By chance has anyone done the .PRG files for Mach ?
If so,would you share them?
And are there any others I should know about ?
Like I said, I am just starting out on CNC lathe and need all the help I can get !! ( That would be NCPlot )
Thanks in advance
If you need reference
http://www.machsupport.com/docs/Mach3_Threading.pdf
Page 33 describes the G76 cycle
Scott
www.sdmfabricating.com
Old 09-27-2011, 11:03 AM
jhowelb is an unknown quantity at this point
Look into LazyTurn.
LazyTurn
"Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson
Old 09-27-2011, 12:06 PM
Scott_M's Avatar
Hi jhowelb
I am not sure I understand your reply or perhaps you misunderstood my request.
I am using Mach turn. It works fine and threads fine. What I am looking for is a way to get NCPlot to plot the G76 move correctly. NCPlot keeps the info for these canned cycles in .PRG files. However Mach turn uses a different format for the G76 call and the plot is incorrect. I am just looking for a way to get NCPlot coordinated with Mach.
Scott
mach3 post files Exodus8931 Post Processors for MC 7 07-13-2011 08:35 AM
Mach3 and .stp files Sandiapaul Mach Software (ArtSoft software) 1 12-13-2009 09:06 AM
Need Help!- getting STL files into Mach3 Drools General CAM Discussion 2 09-08-2009 01:53 PM
Mach3 config files Konstantin Mach Software (ArtSoft software) 0 05-15-2009 01:42 PM
Need Help!- Import/Convert DXF or PLT files to Mach3.... Mikael Mach Mill 3 12-25-2008 03:33 AM
