Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 03-15-2011, 02:36 PM
camtd is on a distinguished road
Dxf file
Is it possible to save and look at the dxf files that are imported into NcPlot? It seems that once I closed the layer manager I have to reimport. Is this how NcPlot works for this feature?
Old 03-15-2011, 11:03 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
There are a couple of ways to overlay DXF files onto a backplot. First, you can specify a DXF drawing in the machine configuration on the viewport settings page. This option loads the drawing whenever the configuration is active. Another option is the 'Set as reference' tool under the View menu. This will set whatever is currently displayed on the viewport as the background image, including a loaded DXF file. This image will remain until you clear it or a machine configuration is changed.
Thanks,
Scott
Need Help!- Converting a pdf file to UG part file gaoxingdcf UG NX 1 05-19-2010 07:47 PM
converting a .sldprt solidworks file into a .stp or parasolid file avogtster Solidworks 3 02-26-2010 01:40 AM
converting a mastercam 9 file into a Solidworks file Michael82 Solidworks 5 04-17-2009 01:14 PM
Need Help!- Need a favor. STL converted to part file or solidworks part file. Cmzwirner Solidworks 3 12-11-2008 07:45 AM
help with pst file DIY'er Post Processor Files 0 11-20-2007 05:55 PM
