| NCPlot G-Code editor / backplotter Discuss NCPlot software here. |
| Hi Scott, This is my first Post, I'd like to start off saying: Awesome software!, it is a must have as far as I'm concerned. I like the new rotate tool and was wandering if you are going to update the script command NCPRotate to work with the added functionality? Also would it be possible to modify the MultiStep tool to multi-rotate using different parameters for each rotation? Thanks M~code |
| M-code, Thanks! I can update the NCPRotate script function, that should be no problem. I'm curious about the MultiStep rotation though, what sort of application do you have that you need different rotation settings for each pass? Thanks, Scott |
| Thanks for the quick response, I have written apps for 5 axis rotations and see that the MultiStep rotate could be useful in calculating rotation results if the dialog allowed each rotation to have its own plane and rotation center values. It works fine as is, rotating one plane at a time, but thought it would be nice to implement it in the MultiStep tool. By updating the Script command it will be easy enough to use a script for that purpose. It's also handy for Post development and for verifying Rotary Set-ups and 5 axis drilling positions. Thanks again Scott, M~code |
| M-Code, You may want to also take a look at the Address Calculator tool. I'm not sure if will be helpful in your situation but I'd be glad to hear your thoughts on it. If you'd like to see some examples, there's a few on the NCPlot web site's forums page under the "Macros" sub forum. Thanks, Scott |
| WOW! how did I overlook that tool. I checked out the examples you wrote and applied them to the text to g-code output and I can't wait to put it to use. I can't over state the power of your software for programmers who want to customize their abilities and add value to themselves. I also would like to mention that your macro translator tool has been very handy and it's the only tool like that around. I'm looking forward to your updates and I'm always checking for the next beta. Thanks Scott, M~code |
| Newbie- Run G-code from script | leif_brunosson | LinuxCNC (formerly EMC2) | 1 | 11-11-2008 01:39 PM |
| Need help with VB script Syntax Please. | Adamj12b | Mach Software (ArtSoft software) | 6 | 09-18-2008 07:18 AM |
| Newbie- VB6,VB.net,VB script,What one??? | hydrospin01 | Visual Basic | 11 | 05-24-2008 08:09 PM |
| Macro/script-can this be done? | Splint | Rhino 3D | 3 | 02-12-2006 09:50 PM |
| Script errors | anoel | Forum Questions or Problems | 5 | 01-13-2005 10:29 AM |
