| NCPlot G-Code editor / backplotter Discuss NCPlot software here. |
A new version of NCPlot is now available at www.ncplot.com! ************************************************************* NCPlot v2.21 Release Notes September 12, 2010 Improvements The tools "Break Arcs Into Lines" and "Break Arcs at Quadrants" now support both absolute and incremental endpoints as well as center points. The tool "Break Lines Into Segments" now supports both absolute and incremental endpoints. When the subprogram setup is set to warn if sub not found there is now an option to cancel program execution when the message appears. Enjoy! Scott |
Hi Scott, Can you take a look at the following program snippet and check if it is ok. I am toying around with scaling and rotation using G68 and G51, havent yet tried it on a machine. I was using NCPlot for the development of this as there will be variables used, i am getting strange results from the plot, although i have not used these codes together on a machine so am unsure if my syntax is correct or if ncplot is correct. .... O1000 (NUMBER 0) G51X0.Y0.Z0.P3(3 TIMES BIGGER) G68X0.Y0.R45.( ROTATE 45 DEG ) N40G0X0.Y3.4 N50Z-58. N60G1G94Z-60.F700. N70G3X-.252Y3.388J-2.72 N80X-1.973Y1.646I.176J-1.896 N90X-2.04Y0.I20.333J-1.646 N100X-1.973Y-1.646I20.4 N110X-.252Y-3.388I1.897J.154 N120X0.Y-3.4I.252J2.708 N130X.252Y-3.388J2.72 N140X1.973Y-1.646I-.176J1.896 N150X2.04Y0.I-20.333J1.646 N160X1.973Y1.646I-20.4 N170X.252Y3.388I-1.897J-.154 N180X0.Y3.4I-.252J-2.708 N190G0Z5. G69 G50 M99 Thanks, Keith. |
Scott There's seems to be a bug in the rotary work . Where this code is supposed to make the 4th axis "A" rotate 2 revolutions. However it only plots 1 revolution. % O0001 N1 G0 G17 G40 G69 G80 G90 N2 G91 G28 Z0 N3 G90 T1 N4 G54 M06 N5 S1000 M03 N6 M11 N7 G0 G90 X-7.0 Y0.0 A-90. N8 G43 Z3.0 H1 N9 G01 Z2.5 F10.0 N10 G01 G91 X6.5 A720. F100.0 N11 G01 G91 X-6.5 A-720. N12 G0 Z3.0 M05 N13 G91 G28 Z0 N14 G0 G90 X0 N15 G91 G28 Y0 M30 % Your help would be greatly appreciated. Bknight |
| NCPlot v2.07 is now available | MetLHead | NCPlot G-Code editor / backplotter | 0 | 07-28-2009 08:21 PM |
| NCPlot v2.06 | MetLHead | NCPlot G-Code editor / backplotter | 0 | 03-11-2009 06:53 PM |
| NCPlot v1.2 now available | MetLHead | NCPlot G-Code editor / backplotter | 0 | 04-16-2008 08:13 PM |
| NCPlot v2.01 now available | MetLHead | NCPlot G-Code editor / backplotter | 32 | 05-13-2007 10:24 AM |
| Need Help NCPlot V1.1 | Switcher | NCPlot G-Code editor / backplotter | 3 | 07-14-2006 03:40 PM |
