| NCPlot G-Code editor / backplotter Discuss NCPlot software here. |
These beta versions are for testing only and are intended to help us work out problems before updates are released. To download, go to www.ncplot.com and click the NCPlot v2 link. ************************************************************* NCPlot v2.20 BETA 8 Release Notes July 31, 2010 Fixed a bug in the subprogram handling that was created by the previous beta release. Updated the new M98 subprogram call format: M98 P1 Q1 L1 P = Program number Q = Block number L = Repeat count Fixed a run time error that appeared if you tried to print from the viewport print preview without opening the setup dialog first. Fixed a run time error that ocurred if you deleted the 'Script Timeout' setting on the preferences dialog. Changed the way the file names are displayed for the open documents: - The application title bar always displays the full path of the active document. - The document title bar, the open files toolbar and the viewport will display just the file name unless one or more files has the same name. If one or more files has the same name then the full path is displayed for these files. Added new edit tools "Jump to Top" and "Jump to Bottom" that will move the cursor to the beginning or end of the file, respectively. Thanks, Scott |
looks as thought the full address is not showing in application title bar but is in macro translate window title bar. I had to uninstall and reinstall to show jump to top and jump to bottom (this may just be my system) otherwise all looks to be working fine |
| Hi Pat, Thanks for the feedback, I finally noticed that the full file path does not show up when the documents are maximized. I'm working on a fix for this. The toolbars are supposed to reset when you do an install, which is why those items showed up when you did that. You also could have reset the toolbars from within NCPlot using "File / Reset Toolbars". Thanks, Scott |
| NCPlot v2.06 beta 5 now available | MetLHead | NCPlot G-Code editor / backplotter | 1 | 12-13-2008 12:27 PM |
| NCPlot v2 beta 16 now available | MetLHead | NCPlot G-Code editor / backplotter | 0 | 11-15-2005 08:24 PM |
| NCPlot v2 beta 15 now available | MetLHead | NCPlot G-Code editor / backplotter | 0 | 11-08-2005 08:11 PM |
| NCPlot v2 beta 14 now available | MetLHead | NCPlot G-Code editor / backplotter | 0 | 10-25-2005 07:49 PM |
| NCPlot v2 beta 13 now available | MetLHead | NCPlot G-Code editor / backplotter | 4 | 10-22-2005 12:05 PM |
