Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 05-23-2005, 12:37 AM
*Registered*
jonbanquer is on a distinguished road
Machine Specific Canned Cycles
Need a way to customize NC Plot for machine specific G codes. As an example we use G12 and G13 to cut holes all the time on our Matsuura's and need away to verify / backplot. Our Matsuura's have Yasnac i80M controls.
Here is an example of some couterbores I just programmed in BobCAD-CAM. Every BobCAD-CAM user needs a decent backplotter AFAIC because BobCAD-CAM has nothing usable.
N107(T7 = 1/4" END MILL)
G8090G40G49G17G0Z0
T7M6
G54X2.3Y-.314S5000M3T8
G43Z2.0H7M8
Z.1
G61
G1Z-.25F12.0
G13D27I.0715L2
G0G40Z.1
X21.9
G1Z-.25F12.0
G13D27I.0715L2
G0G40Z.1
X23.9
G1Z-.25F12.0
G13D27I.0715L2
G0G40Z2.0
X22.6 Y-13.69
Z.1
G1Z-.25F12.0
G13D27I.0715L2
G0G40Z.1
X23.6
G1Z-.25F12.0
G13D27I.0715L2
G0G40Z.1
Y-14.69
G1Z-.25F12.0
G13D27I.0715L2
G0G40Z.1
X22.6
G1Z-.25F12.0
G13D27I.0715L2
G0G40Z.1
X1.6
G1Z-.25F12.0
G13D27I.0715L2
G0G40Z.1
X0.6
G1Z-.25F12.0
G13D27I.0715L2
G0G40Z.1
Y-13.69
G1Z-.25F12.0
G13D27I.0715L2
G0G40Z.1
X1.6
G1Z-.25F12.0
G13D27I.0715L2
G0G40Z.1
G49Z0M5
G53Y0
jon
Old 05-23-2005, 01:21 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Jon,
Can you tell me what the command format is for your G12/G13 blocks?
G13D27I.0715L2
G13 = Counterclockwise circle
D27 = ?
I.0715 = Radius ?
L2 = ?
Thanks,
Scott
Old 05-23-2005, 11:53 PM
*Registered*
Originally Posted by MetLHead
Jon,
G13D27I.0715L2
D27 = ?
I.0715 = Radius ?
L2 = ?
Thanks,
Scott
D27 = cutter compensation for tool 7
Frequently a shop "standard" is to go 20 higher for cutter comp.
Example:
T1 cutter comp would be 21.
I believe this started because height and diameter comp are held in the same register in Fanuc type controls (which are the standard of the industry even if I prefer a Haas control. :>) )
You are correct I does equal the radius. I = X, J = Y, K = Z
L2 = repeat the canned cycle twice. L is a very, very common command for designating how many times to repeat a canned cycle. Haas and FADAL also support the L word.
jon
Old 05-24-2005, 07:04 AM
MetLHead's Avatar
Gold Member
Jon,
Hmmm.... To properly backplot this, I'll need to add support for a tool table.
I am familiar with the L parameter, but it is usually used in conjunction with G91. Does your program repeat the G13 at the same location?
By the way, after some checking I discovered that the G12/G13 is not hooked up as of beta 6. This will be fixed for the next beta.
Thanks,
Scott
Old 05-25-2005, 12:15 AM
*Registered*
Jon,
Thanks,
Scott
"Hmmm.... To properly backplot this, I'll need to add support for a tool table."
Correct.
On rereading my post I think I did a very poor job explaining what you understood anyway. The tool diameter must be figured in with the I value ( tool diameter + I x 2 = size of hole.)
"Does your program repeat the G13 at the same location?"
Yes.
jon
Old 05-25-2005, 06:51 AM
MetLHead's Avatar
Gold Member
I'll look and see what needs to be done to accomplish this.
Thanks,
Scott
Old 05-27-2005, 12:10 AM
*Registered*
Scott,
How do you feel about establishing a database inside NC Plot for specific CNC machines ?
If you opened the API for NC Plot with something like the SAX Basic Scripting Engine the development work of making specific machine canned cycles could be shared by customers of NC Plot instead of you having to do everything.
http://www.sax.net/activex/basic/
jon
Old 05-27-2005, 06:19 PM
MetLHead's Avatar
Gold Member
Jon,
I may go in that direction for a future release, but for now I'm going to concentrate on getting this version ready for release. I think I'm at the point where I'm going to start going through everything with a fine tooth comb rather than add any more features. But that doesn't mean I won't listen to suggestions . I think you'll like the next beta, there have been some nice changes to the UI.
Scott
CNC Glossary CNCadmin CNCzone Club House 17 03-09-2008 04:08 PM
My First CNC Machine, Mr. Chips Mr.Chips DIY-CNC Router Table Machines 81 02-10-2007 10:04 AM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 03:43 PM
FeatureCAM Expands Product Offering with Machine Simulation CNCadmin Product Announcements & Manufacturer News 0 01-21-2005 07:58 PM
Incremental Canned Cycles? Rekd Haas Mills 16 11-15-2003 01:23 AM
