Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 02-27-2010, 10:11 AM
patcareyis is on a distinguished road
NcPlot v2.20b6 feedback
File name is shown 4 times. It looks as though after
(save as) in Ncplots header it shows file path string and then file path string with file name.
With more than 3 files open you run out of room to display full name string in the open files toolbar. Maybe show file name and not full path in toolbar and show full path in Ncplots header and viewport header only
Enclosed is screenshot
Translate settings window if I use multistep Ncplot locks up. I’ve tried multiple settings and all lock up using one step at a time works fine even one step under multistep tab and it locks up
Could you add an option to rotate command to act as selected codes origin point (i.e. bottom left, top right, ect.) after rotating.
Pick points only work to snap to a G-move point in existing program maybe have it select the pointer coordinates or use hot key to capture pointer coordinates shown in pane in bottom left of window
Printer interface looks awesome it's much faster and more user friendly than before.
Could you maybe add radial buttons to enable\disable show tick, rapid moves, Marker, and plunge moves to viewport print preview.
Also maybe an option to add the file address and name, and type in notes to a header\footer to viewport page being printed
Old 02-27-2010, 10:39 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
I'll have to see what I can do with this... right now whatever is being displayed as the document title is what gets displayed as part of the application window title.
I haven't seen this yet, I'll have to find out what I broke.
Not sure what you mean... can you explain in a little more detail?
This is on my wish list. I would like to be able to pick other points off the viewport like center points and intersections.
Thanks, I'll put this on my list.
Scott
Old 02-28-2010, 01:55 PM
Well if you were to draw a rectangle around the item inserted and set origin point as bottom left, top right or center, ect. (Well use bottom left) so that coordinates where X0.0 Y0.0 at the origin point and then rotate at a point that moved the extents of X and/or Y, + or – X0.0 Y0.0 to have they ability to reset part origin to the X0.0Y0.0 after rotation would save having to move part manually
If origin point were say X2.12Y3.01 then after rotation origin point would be reset at X2.12Y3.01 This would work similar to how G92 sets an offset as a soft home instead origin point would act as the part home
This probably would only be useful on x,y programs as I program for laser and plasma cutting of sheet steel this would save some time when inserting code or dxf into existing programs.
I write code in G90 and G91 and set part origin to X0.0Y0.0 and write code for part as G91 and arrange it on sheet in G90 so to move a part I just adjust G90 and not the G91 code so I always set an origin point for the part
Code snippet would be as
G90
G00X.25Y.25
G92X.0Y.0
G91
G01
X1.0Y0.0
Y4.0
X2.0
Y1.0
X-3.0
Y-5.0
G90
G00Y5.5
G91
G01
X1.0Y0.0
Y4.0
X2.0
Y1.0
X-3.0
Y-5.0
G90
http://www.filefactory.com/file/b0c1...igin_point.dxf
Old 03-02-2010, 06:29 PM
runtime estimate problem
Looks as though run time estimate is not calculation arc radius in its program extents. I’ve tried converting to r instead of i and j, tried inc. and abs. arc centers.
Here is a program and config. file
Old 03-02-2010, 07:58 PM
MetLHead's Avatar
Gold Member
That is wierd, I know this used to work. I must have broken something somewhere along the way but I'll get it fixed.
As for the rotation thing.. I think I've got it now, thanks for the explanation.
Thanks,
Scott
NCPlot v2.07 is now available MetLHead NCPlot G-Code editor / backplotter 0 07-28-2009 08:21 PM
NCPlot v2.05 now available MetLHead NCPlot G-Code editor / backplotter 14 09-15-2008 01:39 PM
Need Help NCPlot V1.1 Switcher NCPlot G-Code editor / backplotter 3 07-14-2006 03:40 PM
HELP W/ NCPlot MicoMachine General CNC (Mill and Lathe) Control Software (NC) 1 01-28-2006 02:48 PM
NCplot V2 CNCadmin NCPlot G-Code editor / backplotter 6 04-21-2005 11:10 AM
