- dxf config files for NCPlot
In NCPlot, you can assign gcode (and other) setup values based on layer names so future drawings will automatically bring in these values without re-editing them. Of course, you have to shut the program down after changing a layer, before they're visible...but it does work.
I recently found need to edit all layers to add G54,G55....yet I can't find the config file that holds the layer definitions. I even did a windows explorer search for *.* then sorted for date (after changing/saving a layer inside ncplot so the config file would be updated...aka file date changed too) but no files in the ncplot directory reflect todays date.
Does anyone know the filename of the file that holds the layer definitions and where it's located?
- You may not post replies
- You may not edit your posts
Forum Rules
