Exporting G code to dxf
Results 1 to 4 of 4
Thread: Exporting G code to dxf
    Nov 2005
    Default Exporting G code to dxf
    I am finding Ncplot a real go to tool for evaluating and working with .NC files.
    When I have my G code plotted out it shows the rotation axis with the cutting action correct. But when I export that out to .dxf format and open it all the lines are on top of each other and no longer shows a rotation. Attached are two screen shots to illustrate.
    Is there a way I can get a dxf file to look like the plotted 4 axis .Nc file?
    Thank You
    Exporting G code to dxf-capture-jpg
    Exporting G code to dxf-capture2-jpg
    May 2007
    Germany
    Default Re: Exporting G code to dxf
    Hi camtd,
    please have a look at the attached screenshots.
    Opened from the samples folder of NCPLOT the file Macro B Sample looping.nc
    Saved the plotted graphic in dxf format to disc.
    Opened with TURBOCAD and here it is. Perfect
    NCPLOT itself seems to handle z-values in dxf files all as zero or even suppresses them.
    Hope this helps !
    RIchard
    Attached Thumbnails Attached Thumbnails Exporting G code to dxf-looping-turbocad-jpg   Exporting G code to dxf-looping-ncplot-jpg
    Aug 2003
    France
    I have the same exact problem with B backplotting i'd like to save in DXF... anyone would have an idea?
    ArchieF, Looping.nc sample file backplot is a 3 axis backplot on different planes (G17/G18/G19) and this is ok.
    May 2007
    Germany
    anorec,
    would you upload a sample file ?
    Richard
