- SketchNC work in progress build available
Hi Scott,
works fine here but I'm missing the Chain All / Chain Layer Tool .
And how does Convert True Type Font work? Nothing happens if I select it from the menu.
Cheers,
Richard
Richard,
The 'Convert True Type Font' doesn't do anything, it is leftover from StickFont Editor which is what the application is based on. I just forgot to remove it from the menu.
A few other notes...
Chaining is done with the 'Cleanup' tool.
The 'Select Chain' tool doesn't work unless the drawing has been chained.
The 'Save' and 'Save As' buttons aren't hooked up yet in the G-Code program pane. Likewise, the cut/copy/paste shortcut keys are not hooked up yet but the toolbar buttons DO work. Oh, and the 'find' button isn't hooked up yet.
The G-Code Header and G-Code Footer don't do anything yet, this is because I am planning to go to a post style output method.
I am planning on adding drawing tools for hole patterns.
The command line input accepts expressions anywhere a numeric value is expected. So for example you can scale metric to inch by entering a scale factor of S(1/25.4).
When copy and pasting drawing elements the pasted drawing go on to the default layer instead of their original layer. This is something I need to fix yet.
I am planning on making a 1-click method for transferring a backplot from NCPlot into SketchNC. Likewise for transferring code from SketchNC into NCPlot.
I'm considering supporting both True Type and stick fonts as drawing elements. Actually, I'm pretty certain I will end up doing this.
I think most everything else is hooked up and working. I want to hear about any problems you run into or suggestions!
Thanks,
Scott
I've updated SketchNC, here's what's new:
I hooked up the Save & Save As buttons on the G-Code program window. They currently perform the same function as there is no display of what the file name is.
Hooked up the Find and Replace functions.
Added ability to change the editor font.
Enabled colorizing of the editor text.
Changed the G-Code output settings window around some and added a few new settings.
Added support for 3Dconnexion devices. There is a configuration window that can be opened from the menu "Edit / 3Dconnexion device settings".
Various bug fixes and enhancements.
You can download this update from the same link as above, just uninstall your current version and re-download it.
Thanks,
Scott
- You may not post replies
- You may not edit your posts
Forum Rules
