StickFont Editor v1.15 is now available
Results 1 to 3 of 3
Thread: StickFont Editor v1.15 is now available
    Registered MetLHead's Avatar
    Mar 2003
    Default StickFont Editor v1.15 is now available
    StickFont Editor v1.15 Release Notes
    August 18, 2013
    Fixed a problem with the startup splash window. It was possible for this window to appear off-screen making the application appear to be locked up when started.
    Thanks,
    Scott
    Banned
    Jul 2003
    Default Re: StickFont Editor v1.15 is now available
    mmmmm I purchased the StickFontV2 today and it has the same frozen startup splash window making the application appear to be locked up when started
    Program is unusable as it is Im at a loss to know what to do here?
    Mar 2003
    The splash window that you were seeing had appeared because StickFont had been told to check for a network license server. By changing a registry setting we were able to turn this off and get your software up and running, but I am still investigating what could have caused the splash screen lock up. If anybody runs into this I would be interested in hearing about it...
    Thanks,
    Scott
