Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 09-11-2009, 02:04 PM
badassdevil is on a distinguished road
Thumbs up router bits
what size router bits does every one use for routing bodies i was going to use 6mm (1/4) but im not sure now
ps thanks to cyborg his soildworks dvd is top draw stuff saved me hours
Old 12-23-2009, 12:57 AM
mattia is on a distinguished road
I'm not running a CNC (yet), but 1/2" shaft straight bits for most everything, including hogging out cavities. Sharp cornered cavities (neck pockets, pickup cavities) are cleaned up with a 3/8" or a 1/4" bit.
I'll be running carbide end mills on the CNC.
Old 12-23-2009, 04:00 AM
svenakela is on a distinguished road
It all depends, you shouldn't decide to run one size. In my shop we use everything from 2 to 30 mm for routing.
Old 12-28-2009, 09:34 PM
ihavenofish is on a distinguished road
im trying to set up streamlined production, and with no tool changer and 2 spindles i decided most of the routing would be done with 1 bit. im going to try a 3/8" straight cutter bit because its long enough for the outline, and still small enough for the corners i need to do.
Where to buy router bits ronateah Wood Working Tooling 15 09-16-2011 05:03 AM
Which router bits set? bkboggy CNC Tooling 2 12-17-2008 04:54 PM
Router bits, End mills v bits bogger44 Commercial CNC Wood Routers 3 12-03-2008 12:06 PM
Where to buy router bits? Matty Zee Australia, New Zealand Club house 2 05-06-2008 10:53 AM
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 03:33 PM
