| Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving. |
Just messing around with my router... this is the second time I've let the chips fly. This is a gnome-sized Gibson LP ripped out of some scrap wood I had laying around. not sure if the coarseness is my cnc, the feedrate, or the crappy ryobi 1/4 slotting it I used. seemed to clean up OK after I hit it with some 220 grit. ![]() ![]()
__________________ Check out some of my vids: http://www.youtube.com/user/blauschuh |
| Looks good, might want to try a ball and bit for the carving, with a low step over (10% of the bit diameter) you wouldn.t get the stairstepping. If you dont mind me asking, where did you get the file you used for the machining, i have been looking for a les paul file myself. I am probably gonna chip into the Les Paul digitizing effort, but really would like to see a sample of the scans before committing. |
| Use a harder wood with finer grain (like hard maple) and you will see much cleaner cuts. Pine and spruce are soft and it's hard to get clean edges. CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
i have a full LP body .3dm file. PM me.... Thanks, I figured that. this was just a scrap i had laying around... i just hit it with some 220 grit and knocked the edges down and it looks good. One thing i noticed is that down one side everything is great, then as the bit travels up the other side there is some tear out. this is literally like a $3 router bit tho.
CarveOne
| Nice work. I am just wondering if you mean that you are sometimes cutting - to the right and then other times - to the left. Routers cut best in one direction - the direction of the arrow. If you "climb mill", at least manually, it tends to make a different sort of cut finish, at least for me.
__________________ Supporting RanaTeckk.com and their Dashboard for MS Project promo code WRLNT-2 |
CarveOne
| where can i buy spindles for diy sized machines | compositepro | DIY-CNC Router Table Machines | 2 | 05-12-2006 08:17 PM |
| How to Ream an odd(?) sized hole | MikeLMR | General Metalwork Discussion | 6 | 08-30-2004 08:09 PM |
