Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 02-09-2005, 11:45 AM
Arch is on a distinguished road
Need help drawing Archtop guitar!
I just bought a new cnc router and am trying to learn how to draw arctop guitar tops and backs inside and out. I don't know how to start my arch. Can it be lofted all as one surface or do you have to draw a lot of wire frames. I have BobCadCam Version 20, AutoCad 14, Rhino 3.0. Can anyone help.
Randy
Old 02-11-2005, 12:22 PM
gregmary is on a distinguished road
Which Guitar did you want to start with
Which Guitar did you want to start with? There are probably other luthiers that have plans that could help. Have you checked www.mimf.com? Good luck with your new toy.
Greg
Old 02-12-2005, 01:43 PM
Thanks Greg. I have 3 different models that I build. I own the Benedetto plans but mine are a little different. I just need to know how to draw the top inside and out. I think I already know but, I was hoping someone who had allready drawn one could give me a few pointers that might speed things up a bit. I can't wait to get this thing in.
Old 02-12-2005, 01:56 PM
DAB_Design is on a distinguished road
Arch, if you have any of it drawn, or pictures of what you are after, I'd be willing to help (it'll be a few days before I can really get to it though -- wierd work schedule).
I'd need to see what you are after though, as I don't know a darn thing about guitars.
Old 02-13-2005, 07:22 PM
Arch,
I have created models for a mandolin and a les paul guitar. I use "sweep blends". I would have to see your plans to know the best way to proceed. Do you have the surfaced mapped? If you understand the surface in the manner similar to a topographical map it is not to hard to map it into a surface. The mandolin I first created the surface map, then use the thickness map to create the inside shape.
Greg
Old 07-28-2005, 04:30 PM
Sam Banout is on a distinguished road
Hello Arch and everyone else,
I am also trying so hard to draw a Les Paul using Rhinoceros, Catia V5, Solidworks softwares.
Just can't figure out how to do it. What is the most convenient and easy software to draw this kind of object?
gregmary, would it be possible please for you to send me your Les Paul drawing so I can see how it's done? it would be very appreciated. you can email me at samirbanout@hotmail.com
Here is how I though it could be done:
1- I started by drawing the guitar profile
2- Then I extrude it to the proper thickness
3- then I draw another profile inside the guitar which will be the path curve to use for the sweep to create a solid part that will be substracted from the guitar body to create the archtop.
the problem I am having is when I sweep a spline over the path, I obtain an empty part without thickness which I can't substract from a solid part.
Any help?
Thank you very much
Old 07-31-2005, 01:42 PM
Unfortunately I can not help with those software packages. I used Pro-Engineer to create my model and I use what they call sweep-blends. You create a series of cross sections and the computer joins them creating a solid. I then import the model into a program that creates g-code and use horizonal finishing to create a tool path at fixed increments in the z direction. What this gives me is a graphical representation of the top that looks much like a topo map. This lets me visualize the 3D nature of the top and I can tweek the 3D model in Pro-E until I am happy with the shape.
I am working on creating a model of a Benedetto style arch top guitar. I have attached a file that shows the technique I am using.
Cheers,
Greg
Old 11-22-2005, 12:48 AM
osoloco69 is on a distinguished road
Hows that archtop model giong? If you get the g-code for the top and back of benedetto's I would love to get a copy of it.
Old 04-30-2007, 11:07 PM
danaos is on a distinguished road
plans
any plans here i realy apresiate
nmantelos@gmail.com
Old 04-30-2007, 11:11 PM
plans
there is some with f holes stile
  #11   Ban this user!
Old 05-01-2007, 12:15 PM
sdantonio's Avatar
sdantonio is on a distinguished road
Have you had a look at this thread.
http://www.cnczone.com/forums/showth...t=24800&page=3
If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
Steven
  #12   Ban this user!
Old 05-08-2007, 12:55 AM
Stepper Monkey is on a distinguished road
I don't know about some of the other programs, but ArtCams modeling sysytem is almost exclusively designed for this sort of thing.
If someone already has the 2-D shapes defined in a vector format, and a good idea of what they want for curvatures and cross-section, I have no problem modeling the parts for you guys in very short order and just posting the export files. I just can't cut them, that's up to you router guys.
Just let me know what stuff you need modeled!
While you are at it, does anybody have an SG Bass (EB0 and EB3) template or blueprints?
Guitar dxf files and fret calculator. ynneb Musical Instrument Design & Construction 5 06-15-2010 02:09 PM
3d Guitar Modeling using Autocad slpd Autodesk Software (Autocad, Inventor etc) 107 11-17-2008 03:42 PM
Problem with drawing? or CAM? CNC Darren General CNC (Mill and Lathe) Control Software (NC) 13 01-05-2005 11:30 AM
archtop guitar Pookie Musical Instrument Design & Construction 6 12-20-2003 08:17 PM
Easiest 3D drawing program NeoMiller Autodesk Software (Autocad, Inventor etc) 1 10-23-2003 05:56 AM
