Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 04-10-2009, 07:07 PM
CyborgCNC's Avatar
CyborgCNC is on a distinguished road
Rendered the Strat again..modified
OK, so I made some modifications to the body contours according to the Blueprint I posted previously...what do you guys think, close enough?
I simulated the render with walnut as the wood this time to shows the curves more...
ID:	79478   Click image for larger version
ID:	79479   Click image for larger version
http://www.cncguitar.com
Old 04-12-2009, 01:53 PM
LiquidGuitars is on a distinguished road
your rendering looks way better to me now..
I got to finish my Strat body and neck build a few months ago here is a photo.
Modeled in Lightwave 3D and cut off the Carvewright wood working system.
Finished body and neck.
LG
keep on trucking!
www.liquidguitars.com
Old 04-12-2009, 07:10 PM
CyborgCNC's Avatar
Congratulations....
That is a a beautiful build. You should talk to the folks at carveright/craftsman, and ask them to pay you.....I think you have taken that thing to new heights!
Here is one of my recent builds:
http://www.cncguitar.org:7171/les-paul/
Designed in Solidworks from the '59 LP plans, and machined with Mastercam (on my home-build CNC router).
A few twists:
-Under the Mother of Perl inlays, there are miniature LED's, so that with a pull of one of the pots, the fretboard lights up (but you cant tell they are there when off)
-Another pull of a second pot, and there is an on-board tuner (both work off a 9V internal battery)
-As you can see from the side shots, the guitar also has a build in USB interface...just plug into a computer, and use guitar rig to jam...one USB cable needed, and nothing more...
Will post some more pics of a recent hollow body LP, with some more surprises...
Old 04-12-2009, 08:08 PM
Very nice!
looks like you have the shape down..
sounds good! last year I designed a nice one with carved X brace intergrated into the top and a 5 lam neck. Building a soild 59" now.
LG
keep on trucking!
Old 12-16-2009, 11:47 AM
silverfoxx03 is on a distinguished road
Is this file available? I was wanting to try to do one of these out of aluminum?
Thanks so much
Clay
Convert rendered STL back into a solid? Axxtion GibbsCAM 3 10-15-2008 02:44 PM
I need a drawing rendered in CAD dougpfaff General CAD Discussion 8 09-23-2008 02:43 AM
Saving rendered image bogger44 BobCad-Cam 4 01-08-2007 07:45 PM
Microwave Housings Rendered in Blender3d Rekd CNCzone Club House 4 05-23-2006 08:20 PM
Handling rendered images HuFlungDung OneCNC 4 06-21-2003 10:22 AM
