Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 09-02-2008, 06:49 PM
Flankman is on a distinguished road
cut from surface
I'm studying the training videos from CNCguitar.org. The training course uses Solid Works & Mastercam. Mastercam uses a command called "cut from surface". This allows your tool to cut the selected sketch at a defined depth. One example would be a slot whose bottom follows a contour. The current application is routing a fret slot so that the bottom of the slot follows the fretboard surface at a specified depth. Is there a comparable command for this in Alibre Cam? Flankman
*.obj to surface in MX2? tesart Mastercam 5 05-28-2008 03:41 PM
3d surface problems panaceabea Mastercam 9 04-10-2008 03:00 PM
Help with surface toolpath. M-man Mastercam 0 04-12-2007 03:02 PM
MDT 6 Surface Cut djzepp Autodesk Software (Autocad, Inventor etc) 0 04-10-2007 10:56 PM
surface toolpath Julian M Mastercam 18 01-05-2007 05:53 PM
