Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 08-01-2004, 02:48 PM
SPEEDRE is on a distinguished road
Wood Carvers
OK, I'm not sure this is the right place to put this so here goes. I have been toying with building a carve/duplicator and one thing nags at me. How does one control the cutting profile?. I mean as the cutter moves in the z axis it seems to follow the arc cenered by the arm holding the router. I would think that one would have the z axis move at a constant verticle position at all times, unless it's direction is 3d as in spherical shapes. In designing the machine I have made motion study drawings and always come to the same conclution, the arc shape. Can anybody help?
Old 08-01-2004, 03:24 PM
turmite is on a distinguished road
SPEEDRE,
You have the concept correct. I am curious though if you are refering to a manual duplicator or a computer controllerd machine. I have owned several different manual trace duplicators of two different designs. The most common is the one like you describe where the z axis is mounted on a pivot that allows the up and down motion. there are other designs though that don't use that concept. One machine is a 4 axis Don Allen built using a parallelogram. The other is a Honeig 3 axis machine that is built much like a moving gantry based cnc router except all the xyz movement is suppliet by human arms and hands.
No if you are asking about computer controlled carvers, that is a different story. All of the one I have seen are basically a 3 axis cnc machine with a 4th axis mounted to hold the piece to be carved. They work in the same way as a milling machine does. Up, down on the z with no pivoting and no arm.
Mike
ps I use a 4 axis wood router as my carving machine now.
No greater love can a man have than this, that he give his life for a friend.
Old 08-01-2004, 03:29 PM
I was refering to the manual type. I plan on useing it to carve guitar tops and other usefull things. But I 'm still troubled by the arc profile, I want to keep it verticle as i cut following the given shapes. To keep pockets and such even all the way down and around.
Old 08-01-2004, 03:36 PM
SPEEDRE I just tried to upload a jpg of a new machine I have designed and hope to start on soon. I don't know if it made it or not. I kinda like guitars myself but my main business is gunstocks. The arc movement will not be a problem as long as you keep your stylii and your cutters to the same dimensions. Where the stylus touches you will get a cut that is identical as long as the two are the same and the machine si built well as square.
Mike
ID:	2994   Click image for larger version
Old 08-01-2004, 03:38 PM
SPEEDRE I need to add a caveat to the last post. If all you are going to do is carve the taop then the manual will work like I described. If you plan to cut pickup pockets build yourself a cnc machine instead.
Mike
ah ha the trick I could not see. I guess I was over thinking the operation of the cutter. thanks
Old 08-01-2004, 03:41 PM
for pickup pockets also. I don't think it'll be that bad. I just need to keep all movement relitive to the stylus right.
Old 08-01-2004, 05:09 PM
SPEEDRE the problem I had while trying to inlett the action area for gunstocks is that the z-head is moving in an arc and therefore cannot cut a flat bottom hole or pocket. Here is an example of what I mean. this is drawn using a 24 in. distance from the c of pivot ot the c of the router motor. Actual pivot for this cut is to the outside of the 3/4" flat bottom bit that sticks out of the bottom of the collet by 1". It measures 42.7894 or something close to it. The two green lines represent the arc from pivot and you can see at the bottom of the 1" deep pocket there is a good deal of material that is levt that you will have to take out by hand or use a router with templates. It actually measures .206" .
Mike
Old 08-02-2004, 03:47 PM
turmite sir this is the problem I want to eliminate. I want to do really cheaply and fairly simple. Any ideas?
Old 08-02-2004, 11:16 PM
Speedre there is only three easy ways to eliminate it. One is with a duplicator that operates like a mill in the z, straight up and down. The other is one of the parallogram duplicators and the last is a cnc. You can of course use a mortising drill to square the bottoms up but thn you have the fixtures and the hand work. In my humble opinion your best bet is a cnc. You will have but very little more invested in it by the time you get a machine made and the bonus of the cnc's capabilities far outweigh the cost. I am in the process of building another duplicator presently and will have more in it that I would a small cnc. I have to have one because of the one off type jobs that I simply cannot take the time or spend the money to have a program written. I also have about 100 different patterns laying around gathering dust that needs to be put to work! Email me off list at Ihatespamnonna01@earthlink.net and of course take out the I hate spam to get it to work. I have something you might be interested in.
Mike
  #11   Ban this user!
Old 08-08-2004, 10:18 AM
ddgman2001 is on a distinguished road
I think carvers are great for roughing in carved tops and contours, neck carves etc. The really high-end ones are probably capable of efficiently doing accurate pockets although I've never seen one used in industry for those purposes. I can't see them being as fast and efficient as an overarm router for profiles and pockets.
If you're building less than 12 guitars a year a hand held router with templates is the most cost effective way to go. If you're doing more than 12 but less than 100, an overarm router will really speed production and capability. The good ones can be setup extremely accurately. Over 100/year you could look at CNC, but there are a lot of companies doing that many a day with overarm routers.
http://www.grizzly.com/products/item...emnumber=G9981
  #12   Ban this user!
Old 08-13-2004, 09:23 AM
dbassva is on a distinguished road
it doesnt matter if the stylus arcs or not....it only cuts where the tip is touching the master......how the router and stylus get there is of no consequence.....it only cuts what it touches, making an exact duplicate....the router and stylus move in exactly the same manner...i have a gemini wood carver from allred....its the best on the market.....i might be willing to part with it if you want to buy one at about half the price.....weve done guitar necks, prs archtops and lynch bones guitars with it.....but i will say this, duplicators are not idiot proof machines...you need to have some skill to work them...i wouldnt use a carver for making the whole guitar...you are better off using a hand router....it takes a long time to cut the wood with a duplicator...what we do is cut them on a pin router first and do all of the pockets and then take it to the duplicator to do the carved top.....same with a neck...we will cut them out on a pin router and then take them to the carver.....except i rarely do this..i can shape a neck with a pin router in half the time it would take to even set up the neck on the carving table, so why bother
Not Wood but works like wood almost foamcutter WoodWorking 8 07-12-2005 04:14 PM
Spindle for metal and wood. Motor size question bgolash DIY-CNC Router Table Machines 2 05-20-2005 11:15 AM
long term stability of wood framed router dave925 DIY-CNC Router Table Machines 17 05-05-2005 11:33 PM
Sand/Bead Blaster wood cutting DDM DIY-CNC Router Table Machines 13 12-27-2004 08:12 AM
How to burn flat images in wood? samualt DIY-CNC Router Table Machines 1 08-27-2003 07:50 AM
