Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 01-09-2008, 03:02 PM
xlr8tr@mac.c is on a distinguished road
Little video of my K2
I was approached by a customer who owns an media company that wanted to film his guitar being made. The end result will a thirty minute(ish) DVD that shows the build of Sabre #2 from beginning to end. I've uploaded the rushes from the first chapter to you tube BUT these are just rushes - some scenes are out of sequence, the '6 hours later' is wrong and the scene where i'm sanding the wiring channel clean is cut short. Also there's no voice over but it does give you a little idea of what we're trying to do.
Anyway I thought you might like a look
They say the camera puts ten pounds on you - he could have told me he was going to use five cameras
Old 01-09-2008, 09:37 PM
*Registered*
Mike Stevenson is on a distinguished road
Very nice work there. I am impressed. The video is very high quality. Finally a machine video where the lighting is good and the camera is not hand held, shakey and out of focus.
Old 01-10-2008, 11:10 PM
rlrhett is on a distinguished road
Very nice. I'm curious about the bits you are using. What kind of bit is the large diameter flat one that you are using to thickness the board? Also, is the metal pin a locating pin so you can flip the part over? Are there two pins, or one.
Thanks,
Old 01-11-2008, 02:37 AM
Thanks,
The large cutter is a solid surface cutter from here
http://www.wealdentool.com/acatalog/..._Trim_225.html
You're quite correct there are two pins per side and they're used to index the body for reverse side machining.
www.morgancustomguitars.com
Old 01-11-2008, 04:26 AM
luthier is on a distinguished road
What's that cool sliding vise/router jig that you used to joint the maple? Homemade or commericial? Thanks.
Marty
Old 01-11-2008, 05:38 AM
Marty
One of these;
http://woodrat.com/
Mines seven years old now but nothing joints figured woods as well.
Old 01-11-2008, 01:30 PM
Ah, a UK tool. I hear a lot of complaining from our European friends about not being able to get tools from the US. I guess this is payback! Nice bit for a CNC machine. The closest I could find in the US is the Wagner Safe-T planer, but it is not designed for a router. I love the WoodRat as well, but it is not for my limited hobbyist budget.
Old 01-11-2008, 01:43 PM
holbieone's Avatar
holbieone is on a distinguished road
http://www.youtube.com/watch?v=9A__kSQhYyw
WOW you have a cool job !
enjoyed the video thanks for posting it
Old 01-13-2008, 03:34 PM
CyborgCNC's Avatar
CyborgCNC is on a distinguished road
Very Nice Work Indeed!!!
...I see that you were using mach3 to drive your router...
What software are you using to design your guitars, and what are you using to create machine (g) code?
Do you mill only the bodies, or do you also use your cnc for necks?
Cheers!
Old 01-13-2008, 03:50 PM
Cheers!
I use a combination of Rhino 4 and madcam for all my design/machining - I tried RhinoCam but found madcam to be simpler/more intuitive for me.
I do everything in house - bodies, necks, inlay, finishing etc. etc. I also machine some of my metal components and a good friend of mine winds the pickups.
http://www.bulldogpickups.com/
  #11   Ban this user!
Old 01-13-2008, 05:50 PM
CyborgCNC's Avatar
That is excellent!
I am very happy to see people achieving great results with the "CNC process." Even though there is a LOT of work to be done after machining, CNC surely does make things easier and more precise (I am a big fan)!
I have chosen Solidworks and Mastercam, and so far, results are great.
have a look here:
http://www.cncguitar.org:7171
Cheers!
video help greenxman Mastercam 2 08-01-2007 10:25 AM
Video monte55 DIY-CNC Router Table Machines 4 02-21-2007 11:37 PM
Video CNCadmin DIY-CNC Router Table Machines 2 11-27-2006 10:14 AM
Video DAB_Design CNCzone Club House 0 07-02-2005 05:34 AM
86 meg video jonbanquer Forum Questions or Problems 26 04-06-2005 09:42 PM
