Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 11-02-2007, 08:38 AM
robinsoncr is on a distinguished road
Banjo Neck Model
Does anyone have a drawing or 3d model of a banjo neck? I have a customer that has inquired if I could machine them on the cnc. I have very little knowledge of how a banjo neck is designed. I'd like to get up to speed before I try to model his.
Thanks,
Chris Robinson
Old 11-02-2007, 08:43 AM
turmite is on a distinguished road
Hi Chris,
Go to www.mimf.com and poke around there. You will have to join to have access to all the files but there may be a print available for a banjo there. Not a model, but it's a start.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 11-02-2007, 11:35 AM
Thanks Mike, I'd forgotten all about that site!
Later,
Chris
Old 11-05-2007, 01:25 PM
NardisAmps's Avatar
NardisAmps is on a distinguished road
Hey Chris, I thought you were on the road with The Black Crowes??
Old 11-05-2007, 03:00 PM
I gave up the weed and road to make cabinets and guitar parts!
Ha, ha ha. That gets me every time!
Chris
Old 11-08-2007, 09:05 AM
Would it be better to model the neck from scratch or have one digitized by a scanner?
Chris
Old 11-08-2007, 11:03 AM
LiquidGuitars is on a distinguished road
I think you get better results by hand modeling a neck or body somtimes.
LG
keep on trucking!
www.liquidguitars.com
Old 11-08-2007, 08:56 PM
Chris it will be tons faster to have the neck laser scanned, and I can tell you where to get the best price.........but as LG said, you actually get a better model if you can model it and especially if you model it in Rhino. I had a guy that posted here on the zone scan a set of bullseye target grips for me. He provided me a nice model that had tons of little tiny triangles in it. It machined nicely but it took me three attemps to get it to load in Rhino and only then by using a 50% version of the scan. Admittedly I have an archaic pc that needs badly to be replaced........but $$$ are tight and I have to make do a while longer. That banjo neck would be at least 3-4 times as large as my grip file was.
Do you have a probe digitizer? You could probe a few critical parts of the neck and import that into Rhino and have a model pretty quickly.
If I can be of assistance let me know. I do have a digitizing probe!
Mike
ps did you ever get your file figured out? Did you see the two elevated sections of curves and tool paths?
Old 11-09-2007, 02:34 PM
Hey Mike,
I'd like to learn how to model this neck. It's more complex than the strat style necks I've been modeling. I think it's the volute where the back of the neck transitions to the angled headstock that is intimidating me. I've been trying to talk my wife (aka Business Manager) into letting me buy a NextEngine laser scanner, but so far, it's a no-go.
A while back, I emailed the guy you had used for scanning but he never returned my email.
Regarding the toolpaths, I saw where the two vertical rows are elevated but I don't have an explaination. I'm going to play with it when I get more time.
Later,
Chris
Old 11-10-2007, 07:45 AM
spoiledbrat is on a distinguished road
If you are willing to send 2D views of this banjo neck, I would be glad to model this neck for you in Rhino 4. No strings attached.
I do have a Nextengine scanner, but I agree with turmite. Rhino will create a better machining surface.
  #11   Ban this user!
Old 11-10-2007, 11:08 AM
Hey brat, can I just call you brat? Since you have a scanner I would like to ask you a question.
Can you use the scanner to just shoot a single scan say every .250" down the length of this neck and then use those points that are recorded to create curves to make a surface from in Rhino? I'm trying to figure out a way to obtain as few points as possible but enough to make the curves so I can then model the part. Not necessarily the neck but anything would work for an example.
Mike
Old 11-10-2007, 12:37 PM
ger21's Avatar
Mike, I was thinking about something like that this morning. Why not use the Mach3 digitising wizard, with the appropriate stepovers, to create curves like you want. Then use Rhinoscript or something to extract create the curves. I know it's not as fast as you'd like, but it should work. The reason I was thinking about this, is that I already wrote a macro for AutoCAD to create a mesh form Mach3's point cloud, and it would probably be better for large models to just create splines and loft them. Man, if I could just find the time to get my router running.
Anyone successfully model a guitar neck? rlrhett Musical Instrument Design & Construction 25 03-14-2009 12:56 PM
Is it possible to Re-carve a neck? bcsolomonganz Musical Instrument Design & Construction 9 10-24-2007 01:13 PM
Banjo Fitting jackson General Metalwork Discussion 8 09-27-2007 10:16 AM
My Les Paul neck Jer7440 Musical Instrument Design & Construction 20 05-29-2007 06:20 AM
My neck needs adjusting turmite Rhino 3D 27 10-29-2004 06:59 AM
