Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 09-07-2007, 04:08 PM
CyborgCNC's Avatar
CyborgCNC is on a distinguished road
SW and MC are at it again!
Solidworks and Mastercam are at it again....
http://www.youtube.com/watch?v=clSG0fvA_5c
Not that fancy this time....just a short 3 minute take on machining another one...
Old 09-11-2007, 03:58 AM
Kammo1 is on a distinguished road
Bro that is amazing and I know there must have been alot of hard work that went into programming that, you sure have got this off to a fine art, well done
Old 09-11-2007, 08:27 AM
CyborgCNC's Avatar
Thank you sir!
Yes, it was a lot of work to get to this point. Two of my biggest challanges were:
a: The design phase in solidworks, as I had to learn how to create these surfaces and solids.
b: Bridging the gap from solidworks, to Machining (mastercam) and finally to cutting (with my CNC machine and mach3).
These are exactly the points which I try to emphasize in my videos so that others can learn.
Old 09-11-2007, 08:32 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Any finished pics?
Another fine job!
Old 09-11-2007, 08:36 AM
CyborgCNC's Avatar
I will take some,and post them later today.
The "warlock clone" is complete, and it looks great.
The "esp clone" is just about done. I am in the process of polishing the guitar, but I need to let the lacquer dry for another week or so, before I begin that process.
I prefer lacquer, but it does take quite a bit to dry. I have heard folks using "catalyzed urathanes" but it is something which I am not sure I want to try because they are toxic. So finishing takes me a long time, but the results are great.
Old 09-11-2007, 08:49 AM
CyborgCNC's Avatar
OK..so I just quickly snapped these..not the best quality, but I will take some better ones and post them as well (the yellow mark on the first, is a reflection of my flash). I will try to take some that show the gloss on the body, becasue it is basically "mirror like."
What do you think?
ID:	43431   Click image for larger version
Old 09-11-2007, 08:55 AM
Switcher's Avatar
Moderator
I think it's very cool.
Did you also cut the neck on your cnc?
Old 09-11-2007, 09:07 AM
CyborgCNC's Avatar
I cut the neck with my router, and also I used the CNC to create the radius of the neck (surface).
The fretboard I acquired from Stewmac pre-slotted, and I cut the inlays with a dremel.
My next project, is to actually cut the inlays on my machine, and I am waiting for a couple of inlay router bits which I have ordered. This is venturing into new territory for inlay routing, but I love a challange!
My next guitar model, will feature:
a. A spalted carved maple top
b. A bubinga back
c. A rosewood fretboard (might go with Wenge or Ebony, still trying to decide)
d. A zebrawood neck-back ( I always liked the way zebra wood looks)
I might decide to have an ebony stripe down the neck, with zebrawood sides. Once I have the wood, I will need to place it next to each other to see if I like the looks.
Thank you all again for your comments.
