Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 06-24-2007, 04:17 PM
Zamm is on a distinguished road
Is my drawing ok? *file now attached*
I am hoping someone could e-mail me at zamminc@gmail.com so I can send a drawing a friend has made for me. I am worried b/c he couldn't draw curver well so instead he amde he curves a little angualr so the CNC shop could take the outer points and make the proper curves. It is also in 2D. I'm just looking for an ok from someone that these drawings would be ok to send to a manufacturer.
Old 06-25-2007, 05:39 PM
here is the drawing
Old 06-25-2007, 10:45 PM
turmite is on a distinguished road
If I were going to be your manufacturer I would want dimensions on the drawing. For instance. The drawing template says the the scale is 2:1, but I imported it into Rhino, and the overall length of the body measure right around 18", which is about right for an electric body. Were does the 2:1 come into play?
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 06-26-2007, 03:28 PM
Thanks for the reply Mike! I will have my friend add the dimension, will the body come out smooth instead of angular?
E-mail sent!
Old 06-26-2007, 04:17 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Your drawing looks fine. It would process just fine. Any fine faucets could be blended out by hand.
***edit***
I see your concern - there are a few jagged edges here and there. I am not sure if that's your concern, but if so, simply smooth them out or look at the attached file - I imported into CAD, Splined it and then DXF'd out in an older version, so the Spline became a polyline which will roll right through most CAM packages. See attachment.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Drawing help brtlatjgt Solidworks 3 06-28-2007 12:33 PM
Drawing help dwacker Dolphin CADCAM 11 05-08-2007 03:53 PM
Need drawing converted seansear Employment Opportunity 5 01-27-2005 09:00 AM
Need drawing converted from .max to .3ds seansear Employment Opportunity 1 01-03-2005 11:51 AM
Drawing ? Ken_Shea OneCNC 4 06-08-2003 10:54 PM
