| Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving. |
Hi, I'm relatively new here, but have logged on from time to time just to lurk and learn. My question is this: I plan to build some lap steels from a piece of 7" - 8/4 mahogany and want to use the main board as the body and neck, but glue wings onto it in order to make it a bit wider and to allow me to cut it into more of a guitar shape. Do I need to joint the pieces before gluing up or will my table saw give me a clean enough cut to do this? Should I run the grain all the same direction, or reverse it from the body? As you can see, I know nothing, but I want to learn and certainly appreciate any help or advice. |
| To get a tight glue joint, you will need to use a jointer on your wood. There are saw blade manufactures that claim to give a cut siutable for jointing, but i have not had any sucess. Just take the time to make a good joint and you will be happier with the result. Brian |
| I figured as much, but just wanted to hear it from someone else. I'm trying to justify buying a jointer. What's out there in the "under a grand" category that is worth owning? I'd like to find a really nice used one, but I'm not sure I'd recognize whether it was in good shape or not. Any suggestions? |
| Some better quality table saws with high quality blades will provide you with a good surface to join together, at least that is what I've read about in some wood mags. Personally I've never seen a saw cut good enough to do it to obtain a really nice joint. I recommend a jointer as well. When jointing, you want to run the board over the cutters so that the grain is running down hill toward the infeed table. If the grain is running uphill, you end up with tear out. Marty |
| and sometimes no matter how you look at the board, you can't avoid a bit of tear out. Joint slowly and keep your fingers away from the knives. I think the jointer is responsible for a majority of wood shop injuries. Marty |
| If you have a CNC with a vac table, you can use it to joint the glue surfaces. Just suck the boards down and machine the glue surface with a sharp end mill. This works great and you don't need another piece of manual equipment.
__________________ Be Good, Be Kind, Be Happy Jay Cowan |
| Well, I'm not entirely new to working with wood, but most of the stuff I've did up until now consisted of "home remodeling" type work. Just basic carpentry skills, I guess. I've got a decent table saw, but after some experimental cuts to test the quality of the surfaces and the glue joints I could expect to get, I wasn't completely satisfied. I've got the "go ahead" from the wife for a jointer at this point, convinced her it was the perfect Fathers Day present, now I just need to decide on one. Alan |
#10
| http://www.garrettwade.com/shopping/...oductID=102816 unless this is production, tough to justify a jointer for cleaning up a few edges for gluing. once upon a time all wood working was done with hand tools; it is neither black magic or that difficult once you make you mind up to do it. edge planing straight and square is a basic skill - but in fairness, to succeed you'll need a good woodworking vice and knowledge of how to put a proper edge on the plane blade. as for a buying a jointer, you could get some good used stuff for a grand, depends how heavy duty you want to go....imo the more you tend toward industrial tools the less disappointed you'll be. |
#12
| In his first post he talked about 7" wide boards. Grizzly is having a sale on 8" jointers. $750 delivered. Good 8" jointers are quite expensive. http://www.grizzly.com/products/G0586
| Jointer question | ZipSnipe | WoodWorking | 27 | 09-16-2008 09:40 PM |
