Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Thread: What's the smallest size cnc router needed to cut a guitar
    May 2006
    can
    I want to make my next router large enough to possibly cut a guitar, does anyone know what the general size would be to cover a wide range size of guitars?
    Thanks Mac
    Mar 2003
    Shelby Twp, MI....USA
    I'd want about 24x36 cutting area, but you could probably get away with a little less.
    Registered Drakkn's Avatar
    Sep 2006
    England
    I am building a machine OD 600mm x 800mm which should be enough - even if the length is wrong you can always do necks using the diagonal length
    Drakkn Custom Shop http://www.cbgyorkshire.co.uk
    May 2006
    can
    Thanks for the replys, I will not be using the router for full time guitar building, but might try to cut one or two for fun, and it's good to know I have the correct size.
    Aug 2006
    macgenby... K2cnc makes a 39/25 just for what you want to do and affordable to let set around, if you do want to play all the time and if you want to play with you machine it's good to go full time. I run my machine 5 day a week and no problems. And I have Mach 3 controller, again no problems. and yes it is a K2cnc... No plug for items above, They just work. And I'm picky. 9lrac9
    Banned
    Jan 2006
    Seattle
    I agree with 9lrac9. I also have a KG-3925-G router from K2CNC. For me it is the perfect size/quality/price CNC wood router on the market right now for making guitars. And if you ever need help with your machine of choice just contact me.
    Ballard Guitar Works
    http://users.adelphia.net/~michaels123/index.html
    Moderator Switcher's Avatar
    Apr 2005
    mydxf.blogspot.com
    Have you watched this video?
    My first CNC guitar being cut
    Registered broby's Avatar
    Apr 2006
    How big does a machine need to be for any job?
    Hold your hands apart about, oh, this much [ ] drawing is scaled of course! Around here (at work) it does not seem to matter how big the machine is, the bossman will always try and put a job on it that is always just a bit bigger than it is supposed to take and then wonders why I grumble sometimes.
    B.
    Jul 2007
    spain
    I visited k2cnc website to choose the right cnc router for guitar building, but we need some help choosing the right options for the router. Can anybody help me?
    thank you.
    Banned
    Jan 2006
    Seattle
    Quote Originally Posted by darwin99 View Post
    thank you.
    Hi Darwin,
    I got your PM. Look at this PDF and you can see the exact options I ordered with my KG3925-G router. If you have your own CAD/CAM system like I do then this combo will get you up and running fast. Let me know if you have any more questions because I'm here to help.
    Attached Thumbnails Attached Thumbnails What's the smallest size cnc router needed to cut a guitar-k2cnc_options.pdf
    Registered CyborgCNC's Avatar
    Jan 2007
    Have you looked at:
    http://www.romaxxcnc.com
    Great router, HALF the cost of K2! Look at the speeds of their larger table....
    http://www.cncguitar.com
    Jul 2007
    spain
    thank you for all replies, I check it now.
  • Page 1 of 3 123 LastLast
    1. Replies: 2
      Last Post: 12-30-2008, 11:14 PM
    2. Gotta start making a CNC router
      By vegeta in forum DIY CNC Router Table Machines
      Last Post: 12-22-2006, 05:26 PM
    3. Gotta start making a CNC router
      By CNCadmin in forum DIY CNC Router Table Machines
      Last Post: 12-07-2006, 02:00 PM
    4. Size of CNC Router to make
      By sdantonio in forum Open Source CNC Machine Designs
      Last Post: 11-16-2005, 03:00 PM
    5. CNC router for making acoustic guitars
      By lesnesman in forum DIY CNC Router Table Machines
      Last Post: 09-05-2005, 11:27 AM
