Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 12-29-2005, 10:40 PM
Trainhound is on a distinguished road
Guitar parts g-code
Hi!
I'm a luthier and I'm very new to cad/cam. I built my own wood router and it seems to run very well. I'm still getting my feet wet with Rhino so I haven't been able to design any guitar parts with it. I just wanted to see if there are any other luthiers out there that might be willing to share some guitar related g-gode? I am primarily a classical builder and some day I hope to be able to write code that would be able to cut out my venetian cut-away soundboard design along with the soundhole and rosette trough all in one cut. Right now I'm trying to design a classical bridge in Rhino.
If anyone has anything related to luthierie I would be very greatfull.
Ed.
Old 01-27-2006, 08:47 AM
Ed_R is on a distinguished road
Hey Ed! I'm in much the same boat, only I want top carve and neck carve stuff
Old 05-22-2009, 07:38 PM
restos is on a distinguished road
I´m too...
Old 05-28-2009, 04:41 PM
dbassva is on a distinguished road
i may not be following what you are asking, basically what you do is draw it in cad and then use cam software to generate the code...if i was to just give you the code,each nc processor has its own parameters so you have to make sure it can read the code...if you have a drawing i can generate the basic code for you, but we would have to talk a lot of specifics
Old 05-29-2009, 11:06 AM
DIFF OVER is on a distinguished road
guitar / bass nc code
With a suppllied model i would help anyone with some nc code. You would be responsable for an accurate model, tool list and material dimensions.
I will supply accurate code, you would need to add prep codes, tool change, misc codes based on your machine. The tool path itself will be std code.
If Fanuc / Okuma mill - no problem.
All in fun.
I have offered before but no takers.
I use SW 2005-2009 and all Esprit Packages ( mill, turn, mill/turn, 5 axis, grind and robot, not edm yet ), std and mold.
