Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 01-23-2012, 07:33 PM
Montabelli is on a distinguished road
projeting onto surface
I'm looking for info on software, I have used mastercam for years, but I need to find other cad cam packages which can project tool paths onto surfaces to generat arches etc for instruments. at a lower initial price than mastercam. any of the ones you guys are using have the capability to project ? how about progecting a projection and adding the depth?
Old 01-24-2012, 02:08 PM
mrquacker is on a distinguished road
I believe Sprutcam7 has that functionality, and that's only around $1000
Old 02-02-2012, 09:43 AM
Thanks, it also appears that visual mill and rhino cam expert and above, and Aspire expert and above . Artcam should too I suspect. if any one knows these to be incorrect, please post.
Surface over a surface problem omnitech FeatureCAM CAD/CAM 6 10-20-2011 09:42 AM
Need Help!- Fillet surface to surface problem vincent13 Mastercam 6 02-10-2011 06:15 AM
Need Help!- MX3 SURFACE TO SURFACE TRIM 82rouled Mastercam 1 05-18-2009 12:02 PM
Need Help!- Surface to Surface Filleting and Trimming cowpoke Mastercam 6 03-17-2009 08:42 AM
cut from surface Flankman Musical Instrument Design & Construction 0 09-02-2008 06:49 PM
