| Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving. |
I hope you guys have some experience and can direct me correctly. I have some 2" thick solid Birch planks. The problem they are only 5" wide. I have a jointer that I was thinking of using to get a good edge and laminate them to make a piece wide enough to make a Tele body. Questions, what glue should I use and should I be using dowels/biscuits to reinforce the joint(s)? Thanks for the help.
__________________ Thank You. |
| Use regular yellow woodworking glue, and no dowels or biscuits. If the surfaces are flat, an edge glued joint is stronger than the wood itself.
| Exactly what Ger21 said... I have always used Titebond, never used any dowels or biscuits, and never had a problem... Do not over tighten the clamps, since you will squeeze all the glue out....just enough to get some squeeze out and to make the seam disappear (if you did a good job on the joiner, this will be the case....dry fit them, there should not be any gaps when help up to a light...)
__________________ ------------------ http://www.cncguitar.com |
| Torsion box vs Laminating MDF. | kiwichris | DIY-CNC Router Table Machines | 6 | 06-27-2011 04:26 AM |
| Need Help!- laminating MDF | Drools | JGRO Router Table Design | 12 | 08-30-2010 11:05 AM |
| Birch Laser Ply | dvdlock | Laser Engraving & Cutting Machines | 1 | 08-12-2008 09:04 PM |
| Laminating lead sheet to MDF etc | martinw | General Material Machining Solutions | 7 | 07-21-2007 05:12 PM |
| laminating by vacuum forming? | drcrash | Vacuum forming, Thermoforming Etc | 5 | 11-17-2006 03:24 PM |
