Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 11-28-2010, 08:03 AM
awe_indo is on a distinguished road
Dimension of switch cavity for back control guitar type
Can some one give me info for this problem?
i need dimension,..for 3 ways and 5 ways switch
and the type of tool for cut this cavity....
TQ all
Old 11-29-2010, 12:52 PM
Kammo1 is on a distinguished road
Wow did you make that ?
Old 11-29-2010, 09:00 PM
no.I'm trying to modelling a cort x6 guitar....
its need a switch cavity for 5 way switch,coz it's a back control guitar..can some one help me...
Old 11-30-2010, 04:45 PM
CarveOne is on a distinguished road
Try the Lutherie Information Website for CAD files in .zip format. There is a lot of information on that site.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 12-01-2010, 07:15 AM
hohoho....tq carve one...i'll check out that..
Old 12-01-2010, 11:49 AM
There is a switch outline for a 3 or 5 position switch in the ElecPts.zip file, but I don't know if it is the shape you need. I assume that you make the pocket deep enough to insert the switch assembly.
CarveOne
CarveOne
Old 12-03-2010, 11:34 AM
kimosabi is on a distinguished road
TQ all
Cavity dimension with clearance:
Length 2.4"
Width 1.0"
Deep 1.5"
Old 12-07-2010, 06:16 AM
Was that switch outline the one that you needed? Just wondering. The dimensions that I see in CAD do not match the dimensions that kimosabi has posted. There may be different sizes and shapes for different manufacturer switches.
CarveOne
CarveOne
Old 12-07-2010, 09:23 AM
I mean this switch.
Old 12-07-2010, 12:09 PM
The CAD drawing shows:
Width = 0.375"
Plate length = 1.875"
Hole spacing = 1.625"
It looks like it is for the same type of lever switch.
CarveOne
CarveOne
  #11   Ban this user!
Old 12-07-2010, 04:42 PM
Width = 0.375"
Maybe I don't understand what dimensions you mean, but I mean this (see pic).
All clearances to the switch are ~0,3"
  #12   Ban this user!
Old 12-07-2010, 08:09 PM
The CAD drawing is for the switch dimensions, not the pocket dimensions. From that information awe_indo would need to decide the dimensions to make the pocket. One dimension that is not shown in the CAD drawing is the depth of the switch.
He would need to have one of the switches available to check that this CAD drawing is for the same size switch. This CAD drawing may not be useful to him.
I have attached a JPG version of the 3 or 5 position switch drawing.
CarveOne
CarveOne
back up of the machine, having Heidenhein control iTNC 530 Abdul Haq General CNC (Mill and Lathe) Control Software (NC) 2 06-02-2010 11:17 PM
Back up parameter list 3t control david2259 Fanuc 1 04-06-2010 04:41 PM
RFQ-control plate for a lap steel guitar buckkillr8 Employment Opportunity 12 06-08-2008 08:40 PM
MICRO Adjustment of Lever Type Limit Switch scratch_6057 DIY-CNC Router Table Machines 2 05-16-2007 08:19 PM
MICRO Adjustment of Lever Type Limit Switch scratch_6057 DIY-CNC Router Table Machines 0 05-16-2007 08:47 AM
