Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 11-12-2010, 08:30 PM
daza is on a distinguished road
ESP Forest
Can someone please help me get a schematic for an ESP Forest? I only need the general body measurements and shape. Any help would be greatly appreciated!!! Thanks
Old 11-14-2010, 06:36 PM
DIFF OVER is on a distinguished road
Are you looking to make this guitar by hand or on a cnc router? I have created models for basses/guitars and then sent the end user a 100% true scale pdf of the guitar cut into fours pieces. They then set their printer settings to true scale, print the four sheets and use register marks to create a template that they can trace on wood and then cut out by hand. Also have done it by 3D model programmed for cnc machining.
Old 11-16-2010, 11:54 AM
Kammo1 is on a distinguished road
Wow thanks for that I was just thinking about where I can obtain these kind of plans Can I PM you as to what you have ? Also how much would they be or are they free ? just need to know for sure
Old 11-18-2010, 10:13 AM
NB70 is on a distinguished road
ESP Forest
I attached a model of the ESP Forest from the Google Sketchup Warehouse (done by someone called Kaleb)- you can download it for free. I converted it to DXF(lines only) so you can get the outline and dimensions.
Its not to scale though, but you can scale it yourself : the Forest's nut width should be 42mm its scale length 648 mm.
Nathan
Looking for Forest Edwards Twin plans sdjdave I.C. Engines 1 10-30-2005 04:30 PM
