Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 10-17-2010, 12:15 PM
sdantonio's Avatar
sdantonio is on a distinguished road
RhinoCAM issue
I’m having an issue with RhinoCAM and I hope someone can help.
I’m using Rhino3D 4.0 SR 5 with RhinoCAM 1.0, the part is a bass guitar neck (without the headstock).
The original part is shown in Fig 1, the part is drawn so that the fingerboard (not the back of the neck) is parallel to the x-y plane (also the fingerboard side is on the x-y plane). The back of the neck tapers from z=0.75 (x=0, y=20) to z=0.625, (x=0, y=0). Fig 1a shows a stretched image of the right side view showing the fingerboard (bottom) is clearly parallel to the x-y plane and the back of the neck tapers).
RhinoCAM setup:
1. Part box is set from the RhinoCAM defaults (Fig 2), locate part within stock is not touched (left at the default values).
2. The only tool used is a 0.5” ball mill (no ATC on the system).
3. Figs 3-6 show the cut parameters.
4. Fig 7 shows the final cut
OK, how here it the issue. Based on what I’m seeing in the simulation (fig 7) it appears that RhinoCAM is setting the top of the stock (back of the neck) parallel to the top of the part box (making the part 0.75 inches throughout instead of tapering from 0.75 to 0.625 as in the drawing). I’m basing this on the fact that stock is left on the back of the neck (upper rounded surface) pretty evenly instead of tapering it.
Possible solutions:
1. Cutting the part on a set of ramps to make up for what I’m obviously doing wrong in this file (not my first choice).
2. Setting the thing up right in the first place and doing it properly (always the best choice).
ID:	117030   Click image for larger version
ID:	117031   Click image for larger version
ID:	117032   Click image for larger version
ID:	117034   Click image for larger version
ID:	117035   Click image for larger version
ID:	117036   Click image for larger version
If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
Steven
Old 10-17-2010, 01:54 PM
tony978's Avatar
tony978 is on a distinguished road
if I am looking at Fig 1a.JPG right , To get what you want you need to rotate the part to get rhino cam to cut the z ang. you want . Right now the top of the part is running with the plane of the machine . hope that helps and it is do able with rhino cam
RhinoCam Help Micro Rotors Rhino 3D 9 09-12-2007 09:11 AM
RhinoCAM Help ... It's Gone! Micro Rotors Rhino 3D 3 08-29-2007 11:42 AM
Help with selector switch wiring issue (***actually a motor issue***) BEDFORD Industrial Hobbies (Support forum) 7 04-07-2006 03:19 PM
RhinoCam CarveJunky Rhino 3D 2 06-19-2005 08:27 AM
RhinoCam Dogsione Visual Mill 1 01-25-2005 11:09 PM
