| Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving. |
hey Guys, new to the forum, found it using Google.. ![]() I'm currently starting a Guitar Shop and i'm looking for Files or programme i think it's called in the CNC world. We have 2 CNC machine ready to go, but no programmes for now. we have an operator, but she does'nt do the actually files basicaly. Now, i'm not looking for a hand-out also. what i'de like to find to start with are the following if anyone wants to work something out. Fender Bodies. Fender Necks. Gibson Les Paul accurate 59 Gibson Accurate Flying-V PRS models. Charvel and Jackson models as well. Thanks for taking the time to check my thread.. |
Right now, i'm looking for "files" to be cut basicaly |
[is to reverse-engineer some parts that were produced by several famous guitar companies. This is possible to do, using 3d scanners and some software like Rapidform XOR, then running the results through some CAM software like VisualMill, all of which I can sell you. But - ]
http://www.premierguitar.com/Magazin..._Heats_Up.aspx ] Cheers; Andrew Werby www.computersculpture.com |
| Guys...i'm not trying to start a counterfeit buisness here, i just want to be able to cut something if needed.*as to learn..yes we all start somewhere, don't see anything wrong with that. i will have a part time operator, but he does'nt do any cad work realy |
gimme a break..english is not my first language, I'm french canadian. |
| Legal issues aside (see awerby's post) Bottom line is what your looking for is not what you need. The g-code that runs a cnc machine is machine dependent. While differences may be small between some machines, your risking damaging the ones you have available by trying to run g-code someone else posts. So if you do find some code it would be unwise to try and run it without a programmer to review and modify it for your use. The machine setup is also critical, as it must match the code as well. There are drawings and models of some of the parts your looking for available in this forum. But you will need a programmer to take that and create g-code for you machine from it. In conjunction to the code he will decide how the material and tools will need to be setup on the machine to work with the g-code. |
#10
#11
| I'm not splitting hairs, my best understanding of your first thread was you wanted something to run on a CNC machine, AKA g-code. I gave what I felt was my best recommendation based on the information provided. For drawings and some cad files I told you to look thru the forums, and specifically I'll point you to the Ultimate 3D Guitar Model Thread on the second page of this forum is a good start. Search thru more threads and you should come across more. |
#12
| There are plans all over the Internet, not here. If you are interested in the CNC aspect, then start a little smaller. Research this forum, hire people that can run the machinery, and it should not be that big of a problem. I build guitars for a living, and yes, I have alot of CAD, IGES, STL, and other models that are worthy, but it took alot of work to complete, and, I still do alot of hand work! It's not free, unless you give something back (pay it forward). As a matter of fact, I have another post stating I got stumped on a neck model, and offered free submission of my model if anyone can complete it. Greatest of luck in your ventures, but it seems you have alot to learn yet, or you haven't hired the right people (yet). |
| .txt or "prog" files for gibbscam posts | meredith | GibbsCAM | 1 | 07-10-2009 12:50 PM |
| Need A Quote- .5" x .5" Square 16-18 GA Tubing to cut LOTS | Brad_Davis | Want To Buy...Need help! | 0 | 06-02-2008 09:31 PM |
| "Edit" IGES Files in MasterCam | windrider | Mastercam | 4 | 10-29-2007 08:32 AM |
| Cutting "out" items from a sheet | MrBean | DIY-CNC Router Table Machines | 12 | 01-03-2005 11:55 PM |
| A "Temp Files" section | Mariss Freimanis | Forum Questions or Problems | 3 | 03-22-2004 11:15 PM |
