Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 05-22-2010, 11:36 PM
awe_indo is on a distinguished road
how to flip object accurately
hello all
I am a new person in the world of CNC
I have a problem about how to flip the guitar body or neck accurately
so please help me ...
I've heard about the guitar jigs.
or there are other methods?
Is that Anyone can explain how to make it?
Thx's before...
i hope someone can help me..because this problem really make me confuse...
Old 05-25-2010, 10:32 PM
dustin1706's Avatar
dustin1706 is on a distinguished road
Simply use some holes and dowels to connect your workpiece to the spoilboard and make sure your last step is the contour cut.
As in post #6 of this thread http://www.cnczone.com/forums/showth...186#post780186
JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router
Joes 4x4 R&P in progress
Old 05-27-2010, 09:01 PM
thx's dustin
Old 05-28-2010, 02:39 PM
awerby is on a distinguished road
The crucial thing is to make sure
that the coordinate system doesn't shift when you do the flip. The simplest way is to drill two holes in your spoilboard, right in the middle (along the Y axis) outside the cutting area, and put dowels in them facing up. Drill corresponding holes in your workpiece. Set your Y zero point at the mid-point of these holes, and make sure the part is centered on Y in the CAM software. Then, when you flip your workpiece over and clamp it down again after cutting the first side, it should still be in registration. Just make sure you flip the CAD model accurately along that central Y axis and all should be fine.
DeskProto does it a different way, that also works well, using its 2-Side Wizard. You set up blocks at the front left corner, for the corner of your workpiece to nestle in, and true them with your cutter. Then you fasten down your part and make a cut at a specific location (given by the software) on the back edge of your workpiece. Place the X/Y zero at the front left corner, not in the middle, as in the previous example, and the Z axis zero on top of the workpiece (the thickness of which is communicated to the program). Then when you've cut the first side, you flip the part over, nestle what was the back left corner in the blocks, fasten it down, and run the other side; the software makes sure everything's in the right place. DeskProto offers a free trial that lasts a month (see www.deskproto.com) , so you can try this yourself without having to pay.
Andrew Werby
www.computersculpture.com
how to flip a part cob Mastercam 6 12-02-2008 09:48 AM
Newb, how to flip part idkman General Metalwork Discussion 6 10-20-2008 09:12 PM
Lathe stock flip - how to set parts up? pmurdock Haas Lathes 10 05-04-2008 12:25 AM
How to mill a flip...accurately?? carguy327 General Material Machining Solutions 8 07-25-2006 01:36 AM
bistable flip flop owhite General Electronics Discussion 13 05-23-2004 09:21 AM
