Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Musical Instrument Design & Construction
Musical Instrument Design & Construction Discuss of CNC machining electric guitar body shaping, template making, inlay part cutting and pocketing, neck shaping and carving.
Old 05-12-2010, 12:03 PM
jimmiethekid is on a distinguished road
Mastercam neck pocket toolpath
I am having some troubles getting a strat neck pocket toolpath going. I know this should be SIMPLE, all the other pockets are fine .. I have the 4 screw holes for the neck in the pocket and its screwing me up I think, its not cutting the entire neck pocket its cutting around the inside neck pocket area of the screw holes but not around them. If that made any sense.
I guess I could just not use the screw holes but it would be nice to have them done on the mill and not by hand afterwords.
If anyone used mastercam and is willing to help me out I will email you the file I am working with.
Old 05-14-2010, 09:40 AM
wbegg is on a distinguished road
I had the same problem and my workaround was to eliminate the holes in the neck cavity and carve the surface. Then I do a drill toolpath at the hole locations to drill the necessary holes.
Old 05-14-2010, 11:33 AM
thats exactly what I ended up doing.
Old 05-22-2010, 06:02 PM
wayja is on a distinguished road
I have had the same problem. Could not find a way around this issue and I got frustrated, so one way I got around this was to export multiple "models" out of Solidworks to Mastercam. I would label them neck pocket without holes and neck pocket with holes. So I just chose the neck pocket in the first file and cut it, and then chose just the screw holes in the other file. So basically the first program cuts the neck pocket and the second just cuts the holes. As long as you dont move your stock, it works fine. Does that make sense? The joys of learning as you go!
Wayja
Pocket Toolpath jcnewbie Mastercam 4 10-21-2009 01:16 AM
ISO CAD or toolpath data for CNC routing (body+neck) eurospruce Musical Instrument Design & Construction 4 12-07-2007 09:55 AM
Best toolpath for this partially tapered wall pocket? kprice1658 Mastercam 10 12-03-2007 09:47 AM
Mastercam Guitar Neck Help CyborgCNC Mastercam 17 06-01-2007 10:11 AM
changing mill pocket toolpath to lathe-v9 scolee Mastercam 0 03-25-2007 09:39 AM
