How I use CNC in acoustic guitar building - Page 6
Page 6 of 6 FirstFirst ... 3456
Results 61 to 66 of 66
Thread: How I use CNC in acoustic guitar building
  1. #61
    Apr 2004
    Default Re: How I use CNC in acoustic guitar building
    And finally, here it is together and ready for binding, armrest work, and lacquer. Will post finish pictures by the weekend.
    How I use CNC in acoustic guitar building-img_2769-jpg
    How I use CNC in acoustic guitar building-img_2770-jpg
  2. #62
    Apr 2004
    Here's a few pics now that the lacquer is done. Was a good night. It took about 3 hours to level sand (600 grit) and then buff (med and super fine) the finish. I follow Robbie O'Briens finish schedule from his online course His schedule makes the final level sanding very easy.
    Here's a sample:
    How I use CNC in acoustic guitar building-img_2912-jpg
    How I use CNC in acoustic guitar building-img_2913-jpg
    How I use CNC in acoustic guitar building-img_2914-jpg
    How I use CNC in acoustic guitar building-img_2915-jpg
    How I use CNC in acoustic guitar building-img_2916-jpg
    How I use CNC in acoustic guitar building-img_2917-jpg
  3. #63
    Apr 2004
    Pictures of #12 (mostly) finished. Just need to intonate the saddle. This was an amazing setup. The frets were so flat I only need to level 2 of them, then the initial setup
    came out perfect, no adjustment needed and 6/64" clearance at the 12th fret!
    I have no idea why the pictures are sideways.
    How I use CNC in acoustic guitar building-img_2922-jpg
    How I use CNC in acoustic guitar building-img_2926-jpg
    How I use CNC in acoustic guitar building-img_2927-jpg
    How I use CNC in acoustic guitar building-img_2929-jpg
    How I use CNC in acoustic guitar building-img_2930-jpg
    How I use CNC in acoustic guitar building-img_2932-jpg
    How I use CNC in acoustic guitar building-img_2933-jpg
    How I use CNC in acoustic guitar building-img_2934-jpg
    How I use CNC in acoustic guitar building-fullsizerender-jpg
    How I use CNC in acoustic guitar building-img_2937-jpg
  4. #64
    Apr 2004
    Here's a video of the initial string-up/play. Note to aspiring builders - initial setup never sounds this good. This thing had perfect action by pure random chance.
  5. #65
    Feb 2006
    That is a beautiful guitar! I love your process. I have created two electric guitars on my cnc mill, at work. A Les Paul, and PRS. I have a couple of questions for you. What do you use for a vacuum pump? What do you use, cutter wise, for making fret slots? Speed and feed settings?
  6. #66
    Apr 2004
    Quote Originally Posted by Jer7440 View Post
    Thanks.
    For the pump, I use the same vacuum pump I got form joewoodworker.com. Meant for doing the vacuum bagging, I just put a different type of hose on it to push into the vacuum jigs.
    I use the fret cutter bits from precise bits.com ... BUT.... it is .025" bit, and I found that my slots are little too loose on the fit, so I've started using the .020" shell cutter bits to make they're snug. Maybe spindle runout causing that. I do .010" cut per pass, rather slow (whatever they're listed feed rates are). Running bout 12K rams IIRC.
