I did a close inspection of the toolpath in Mastercam and have found where the error occurred. If the pickup cavity is done as a pocket operation, the finish pass of the perimeter is an arc at the corners (rounded). If I program it as a contour operation, the toolpath is point at the corners (square) Not sure why, but at least I have a work around until the reason becomes clear.
