Latest guitar builds - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 29 of 29
Thread: Latest guitar builds
  1. #25
    Gold Member
    Apr 2009
    Default Re: Latest guitar builds
    Quote Originally Posted by bostosh View Post
    I like the structure on the back this is reminding of the aircraft structures.
    I am doing a billet Dred soundboard, it is ready for the shop, same weight as wood, integral structure from 3/8 plate stock.
    I am seeking the other parts or a complete Dred to exchange the top on.
    Thanks!
    Check out Cole Clark guitars; they make tops with integrated bracing and even integrated lining... As for back and sides, you may consider getting a kit from StewMac and just using your top.
    - - - Updated - - -
    Quote Originally Posted by Kosh View Post
    Nice work Louie! Is that a CF sandwich I see on your X-brace?
    Thanks Kosh! It's actually Honduran rosewood veneer. My next batch, when I get the CNC router up and running, will be CF...
  2. #26
    Apr 2004
    Quote Originally Posted by louieatienza View Post
    Thanks!
    - - - Updated - - -
    What type of bit would you use?
  3. #27
    Gold Member
    Apr 2009
    I have some solid carbide burr-mills, as well as PCD tooling, from LMT/Onsrud. The burr-mills are relatively affordable. The PCD - you better sit down and strap yourself in...
  4. #28
    Apr 2004
    Was wondering how the burr bits would cut in the spruce, but I guess you want to finish sand them anyways.
  5. #29
    Mar 2013
    Glad to see you posting again. Looking forward to seeing more of your work.
