- Set neck/p90 pockets
Re: Set neck/p90 pockets
Also I've tried doing pockets on these but it won't cut out the bottom part of the pickup oposite from the open pocket
I like to keep the machining of features separate that way they can be tweaked or machined at different times. I assume it's the different depths that are causing headaches, but maybe you've got angled surfaces in there too ? Not sure what CAM you are using and what it supports but I do something like this: Make a configuration named "No NJ" (etc) and suppress your cut features for the Neck joint. Then pocket for your pickups. Do similarly for the neck joint with the P90 pockets suppressed - you might be fine that them as-is by using the NJ edge as the machining boundary.
- You may not post replies
- You may not edit your posts
Forum Rules
