Let's Build a Strat - Page 2
Page 2 of 24 FirstFirst 1234512 ... LastLast
Results 21 to 40 of 472
Thread: Let's Build a Strat
  1. #21
    Jan 2006
    THe only thing I dont like about that is that it leaves a hole where there shouldn't be one
    I like the idea of the removable tabs- you machine all but about a quarter-inch or so of material to give yourself a cutting guideline and leave the rest there.
  2. #22
    Apr 2004
    Alamogordo, NM
    Hi Ed
    Yes, that works only for bolt on necks. My kid has been refinishing a Schecter (sp?) that he owns. It has a hole in the same position so some of the commercial makers put a hole there for some reason..
    Larry
  3. #23
    Jan 2006
    Oh they definitely do, I've seenit on lots of different makes. But never on a fender
  4. #24
    Scrapydoo
    Guest
    Default Making a "Strat" style guitar
    Guys,
    I'm a newbie when it comes to this site, but not to guitar making. I see a lot of discussion on cutting the body, but not much on the neck, except for attachment. I prefer the tab type fixturing for sure, it's easy to remove the tab by hand after cutting. I joined this site because I am getting away from template routing. A couple of things to remember when building a guitar, 1) use tone woods (I believe the strat was made from swamp ash), and 2) remember the fingerboard is radiused (I believe Fender uses a 10" radius), and the best fingerboards are made from rosewood or ebony. You might want to read up on the fret spacing and scale sizes. I will try to post some info on the guitar scales later. I own a company that makes dreadnought guitars.
  5. #25
    Jan 2006
    I'm not unfamiliar with guitar-making , myself. And I'm probably a fan of yours. I might have to pick your brain
  6. #26
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Quote Originally Posted by Ed_R
    Works for me!
    I wonder where I can find a .0023 cutter for the fret slots?
    http://www.precisebits.com/products/...I1.x=6&I1.y=13
    UCCNC 2017 Screenset
  7. #27
    Jan 2006
    Gerry, you absolutely ROCK!
  8. #28
    Gold Member
    Jun 2003
    Scrapydoo welcome to the site and it's really good to have you aboard. Do you have a website we can go look and drool!
    Gerry that is a great find and thank you. I just bought a pre-slotted blank because I didn't have a bit and couldn't find one.
    Mike
    No greater love can a man have than this, that he give his life for a friend.
  9. #29
    Jun 2004
    Working a bit more on the model of the Strat Neck. I have been studing the blends between the neck and the headstock and between the neck and the tenon. Here are a few photos to compare the final model against.
    A set of plans is great for outlines, but rarely help with 3D curves and the way different surfaces blend into each other. You have to take the original in your hands and feel the flow of one surface into another.
    Attached Thumbnails Attached Thumbnails Let's Build a Strat-stratneck1-jpg   Let's Build a Strat-stratneck2-jpg   Let's Build a Strat-stratneck3-jpg   Let's Build a Strat-stratneck4-jpg
    Let's Build a Strat-stratneck5-jpg
  10. #30
    Jan 2006
    Wow, looks like you're m,oving right along. You've definitely got the right idea there!
  11. #31
    Gold Member
    Jun 2003
    Hi Greg,
    I downloaded the dxf and when I open it in rhino I am missing one curve (upper left hand looking at the drawing) but I get several multiple curves overlaying each other in different places. ???
    Mike
  12. #32
    Jan 2006
    What DXF?
  13. #33
    Jan 2006
    he is talking about the body.dxf file , it has one of the splines blown.
    I am interested taking a shot at one of these also. I do not have much to offer as far as guitar design goes, but I do have extensive 3d modeling and nc programming experiance to offer. I have several cad packages available for modeling and file translations if needed.
    Ken
  14. #34
    Gold Member
    Jun 2003
    Moldmaker was it missing for you too? Have you checked for multiple entities on top of each other?
    Mike
  15. #35
    Jan 2006
    try this, I added a bridge curves that looks natural.
    The original dxf was created in ProE, it does not do splines well in dxf
    format, but it does have the best igs translator out there.
    Included is a clean dxf & igs file.
    Attached Files Attached Files
  16. #36
    Jan 2006
    here is the igs
  17. #37
    Jan 2006
    Maybe we need to get Moldmaker working on the LP top
  18. #38
    Jan 2006
    I intend to build 2 of them, the machine will not be in till the first of may.
    but that doesnt hinder me from modeling and programming.
    Ken
  19. #39
    Jan 2006
    I'm needing to start the modelling process, but I can't draw a line with a ruler
    So I have a pretty steep learnign curve ahead,
  20. #40
    Jun 2004
    Continuing work on the Strat neck model. You know how it is, triing to grap a free moment here and there. These are a few photos of the tenon end of the neck. Now that I have this end drawn I can make sure it fits into the body. Any suggestion as the amount of clearance that should be allowed between the neck and the body? about .050"? In the past I have made them with no clearance and had to sand a bit to much to get 'em to fit.
    Attached Thumbnails Attached Thumbnails Let's Build a Strat-tenon1-jpg   Let's Build a Strat-tenon2-jpg   Let's Build a Strat-tenon3-jpg
Let's Build a Strat
Let's Build a Strat
