hi everybody this is probably something that everybody wants to avoid i have a multitek box(tek10 amp) with the deskcnc controller mounted to one of my mills (it is running quite good for the last 2 years, maybe 3) now suddenly the x axis motor takes off at random(i push the fast feed button) but stoppage only via kill switch, on top there is a random x-axis creeping(control on, but in standby)and no change in the position display, until it hits the solid endstop. i redid the wiring,replaced the amp with a spare i have,replaced the wiring to the motor/encoder, but no change i had at one point a repeatable run away (6 times) of the x-axis and when i jogged the y/z axis (no problem there) the run away situation evaporated until next time. can anybody shed some light on it, i am at a loss. cant use the machine,do not know where it will go next |
| Assuming there is no tach on the motor, I would check the encoder signal output. Al.
| the funny thing is when i start the control, the run away condition does not appear always,if it does then only at the x-axis.this morning it did it again. 1. jog x-axis in rapid, x-axis started to run away, killed it 2. jog x-axis in rapid, run away again,killed it 3. jog y axis in slow, back and forth 4. jog x axis in rapid, servo moves at set jogging speed 5. run small test program with feed/rapid in x/y plane a fw repetitions, everything fine 6. let it sit for some time (1/2 hour) x-axis starts to creep in slow feed,no position change 7.scratch at the last few hairs on my head hans |
| saga continues started back after coffeebreak , jogged x in rapid and again run away of the axis so i removed the x axis servo motor,checked wiring trough the housing connector (why they route the encoder cable and powercable through the same conduit is something i do not know) but checked the encoder, nothing lose,cable seams to be alright it is an accu-coder model 775a -1000 encoder not knowing if there is cable disconnect or not so i swapped the whole motor/encoder against a known working one.(motor is on bench) joggingin slow/rapid seams to work and my test program is running. my problem might point to a faulty wiring at the encoder/motor end so far test program still running hans |
| Al.
| the sparemotor/encoder is doing okay, it looks that either the encoder/or the big plug at the servo has a loose wire(encoder) i will reconnect back to the machine axis reroute the encoder wires seperately and see what i get thanks hans |
| Thread Tools | Search this Thread |
| couple of sets of Indramat Servo Controller+Mains filter+Servo Motor 9Nm, 4500rpm | bogus105 | EBAY ADS | 2 | 11-16-2011 10:25 PM |
| Need Help!- Changing Fanuc AC servo driver and motor for a regular VFD and async motor | Bordaco | Servo Motors and Drives | 4 | 09-08-2011 05:41 PM |
| replacement motor for PML&Kollmorgen DC Brush Servo Motor | fymroger | Product Announcements & Manufacturer News | 2 | 10-24-2008 03:36 AM |
| Sell Servo Motor, Servo Drive by GSKcnc.com from China | salecnc@hotmail | Product Announcements & Manufacturer News | 0 | 06-03-2008 02:55 PM |
| Servo motor used as spindle motor? | fatal-exception | General Metal Working Machines | 6 | 09-14-2007 02:55 AM |
