Results 1 to 3 of 3
Thread: MC 48 - DNC communication problem
    Jul 2008
    I have acquired a older multicam machine and am having issues with loading programs using the DNC. The controller shows it is a Machine Automation V3.37a m23 i3.58. I did not receive a factory cable so have been using a serial cable with a null modem adapter. It loads small programs up to 2K and runs great, however when loading anything larger it either contains some erratic moves or list an axis as out of range. I assume it lost some data in transfer. Any suggestions?
    Jun 2010
    Go to your port settings, got to advanced and turn transmit to low and receive high. Try that and see what happen...also what are your port setting.
    Jul 2008
    Received and installed factory cable today, settings are 19200 Baud, even parity, 8 bits, 1 stop bit, none on flow control, receive to high, transmit to low. Still not transmitting files over 2k correctly.
  1. PC to CNC communication problem
    By shig22 in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 02-25-2012, 01:30 PM
  2. Need Help!- RS 232 COMMUNICATION PROBLEM
    By fourway in forum Milltronics
    Last Post: 01-05-2011, 05:15 PM
  3. Need Help!- Communication RS-232 problem
    By quasarix in forum 5T/5M
    Last Post: 10-15-2010, 07:58 AM
  4. TNC 370 communication problem
    By Flatdog in forum Bridgeport and Hardinge Mills
    Last Post: 01-09-2008, 08:20 AM
  5. Communication Problem
    By Alex S.A in forum Computers and Networking
    Last Post: 01-28-2005, 10:38 AM
