Results 1 to 4 of 4
Thread: MultiCam MT series questions
    Mar 2012
    This isn't Faye writing this message first off, but rather a co-worker. This might be a bit of a read but I am going to try to make it as short and to the point as possible.
    Currently we are trying to change how we program/operate the two machines that we have, right now we have one computer with engravelab that creates all the programs, both machines access the hard drive to locate the more than 100 programs in countless directories. How I am trying to change the system is by adding a second computer and having engravelab directly send files to the machine through the serial port (we can use the a virtual eithernet port as well, but I want to see if we can get things working first before making it faster)
    Instead of messing around with the one computer that works, I used my personal laptop, installing all the software needed from multicam and engravelab. Next I configured multicam's communication program to use COM4 with 19,200 baud and even parity. Next I set my device manager on my computer to the same settings reducing the speed as per multicam's instructions. Lastly I set engravelab to engrave directly to port, set the port specs to the same as before.
    Whenever I engraved to port, a window would come up with data transmitted, no errors (after a little fiddling around), I even opened the cabinet and viewed the RXD led on the board receiving data. Also after some frustration I changed it to the print spooling option and had the same outcome.
    Here's where I have the problem, after the data had been transmitted, either directly or by the print spooler, the handheld device did not show that anything had been sent, press the start button and it tried to connect to the DNC server (which was disconnected), while reading the multicam manual I noticed that you can select remote or local DNC, went to the utilities directory where the DNC select should be to find it isn't there......
    So now you know how half of my day has been, chasing phantom programs in controller land......I have no doubt the data is getting to the controller but I don't understand why it isn't letting me access it. Somehow I think it has something todo with the controller parameter options that aren't listed in the multicam manual.
    Please fill me in if I am missing anything or something else that I should be looking at.
    Jeremy
    Jun 2010
    Multicam MT series question
    Are you still having these communication issues
    Mar 2012
    Yes we are
    Jun 2010
    Multican MT Series question
    Faye,
    Give me a call....may have to do a Tele Conference and take a look at your setting on your system.
    678-548-1483
    Maurice
  1. Multicam CNC Router Series 1000 User Manual
    By cdemarchena in forum Machinery Manuals & Brochures
    Last Post: 01-28-2012, 02:41 PM
  2. Multicam 3000 Series vs AXYZ 5000 Series
    By adamfilip in forum Commercial CNC Wood Routers
    Last Post: 10-18-2010, 03:54 AM
  3. NEED HELP - MULTICAM 5000 SERIES
    By loyedp in forum Commercial CNC Wood Routers
    Last Post: 09-21-2010, 11:08 AM
  4. Question about a MultiCam 3000 Series CNC Router
    By dennisbwest in forum CNCzone Club House
    Last Post: 12-11-2009, 12:15 PM
  5. Multicam 3000 Series and Weeke
    By gusb in forum Want To Buy...Need help!
    Last Post: 04-16-2009, 05:34 PM
