Results 1 to 7 of 7
Thread: Tool Bit going too far
    Nov 2010
    U.S.A.
    Unhappy Tool Bit going too far
    I am learning 2 operate a Multicam M Series.Router....the problem I am having is that the tool bit goes down 2 far, I am cutting PVC 3/8"thick, when executing the job the tool bit cuts thru the pvc and also cuts thru the sacrifice board..the PVC is 3/8" thick and that is the value I entered when prompted do do so from the Routing Offset screen, I also did set the Surface depth and Max depth using the magnetic block..but i always get the same result (the bit cutting thru the sacrifice board) What I am doing wrong? I am using Enroute3.
    TIA
    Jimmy
    Jan 2007
    CA
    Quote Originally Posted by jimmyCNC View Post
    TIA
    Jimmy
    When you surface the tooling are you surfacing on the spoil board or material? You need to make sure that in Enroute that when you setup your material that you select surface at the top or bottom of material and surface your tooling like wise
    Nov 2010
    U.S.A.
    Cool Depth Problem
    Hi : I am having a problem when sending a job to my Multicam M series CNC machine, my problems is that the tool bit goes deeper than I wanted to..I was cutting laminated foam 1” inch thick, and that was the value I entered on the Depth section of the Router Offset screen, I used a ¼” tool bit. I also set the Surface dept and Max depth using the magnetic block of my table…I did set the surface on the top of the material, and when I defined the plate
    That was the default “set surface at top”.
    The tool bit cut thru the 1” material, but it also cut thru the sacrifice board about 1/8”,I am posting a pic of how it looks like, I do not know what I am doing wrong, I do not know if it is an Enroute issue or if it is a Muticam issue, Does any body have any ideas suggestions?
    TIA
    Jun 2010
    Tool bit going too far
    Ok...lets see 1st 3/8" material reguardless of what it might be is normally not 3/8", if you have a pair of dial calipers, I would suggest that you take 3 measurements and get the average of those readings, that is the number I would pit in to my cut depth + add .010. By adding the .010 you can use max depth override to make sure you cut thru your material.
    Question are you taking your surface and max depth depth reading with the vacuum pump on?
    Nov 2010
    U.S.A.
    Tool bit going down 2 far
    Thank you for the sugestion, I sure will be tying that the next time (getting the 3 measurements and use the average), and to answer your question, yes i do turn the vacuun pump on when I am setting the surface depth.
    Jimmy
    Jan 2007
    CA
    is it consistently cutting to deep, as in no matter what tool you use and what you are cutting? Your going to see some marking on your spoil board but that is a little excessive. do you have an automatic tool changer?
    Nov 2010
    U.S.A.
    Unhappy Tool Bit going 2 far
    No I dont...have one:
    1. Replies: 4
      Last Post: 02-01-2011, 09:10 AM
    2. Replies: 0
      Last Post: 11-24-2010, 03:00 PM
    3. Renishaw tool offset / break probe and tool life management
      By mcash3000 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-20-2010, 10:14 PM
    4. Replies: 0
      Last Post: 02-14-2010, 01:26 PM
    5. Mini-Mill Segmented Tool Disk Upgrade CAT40 10-Tool
      By C.M.I. in forum Product and Manufacturer Announcements
      Last Post: 12-17-2009, 01:36 PM
