Need Help! need info on value sf series
Results 1 to 13 of 13
Thread: need info on value sf series
    Default need info on value sf series
    hi everybody
    i'm looking for some info on a value of a late 90's (?) multicam sf series. this one is 4'x8'
    with vacuum table. i know nothing about these machines but have started building a small one
    for woodworking when this one came up. its supposed to be in decent working shape except for
    as he thinks a board that takes care of one of the motors is shot, everything else is supposed to be
    in good working order, can anyone give an approximate value range for this machine?
    i would appreciate any information i can get,I've tried searching but haven't found out enough
    Jun 2010
    Default Re: need info on value sf series
    The SF machines were some the first machines Multicam ever produced. How much are they asking for this machine, are you going to inspect this machine?
    QUOTE=mikeyd895;2012048]hi everybody
    i would appreciate any information i can get,I've tried searching but haven't found out enough[/QUOTE]
    Dec 2013
    I found a couple of listings 1) $19,000, 2) $32,000. Both of those are overpriced IMHO. A customer of mine bought two 5 x 10s for $16,000 for the pair, including two 25HP vacuum pumps. One had two bad servo drives. The other one has had some issues also. I replaced the servos on the one with Teknic Clearpath SD servos, and did some repairs to the other.
    I've looked at it already and we have a deal for $2500 the way it sits, I've known him and his dad for years and do a fair bit of business with him
    i have no reason to doubt hat he's told me, all working except one board for one motor
    are there any benefits in trying to keep the propriatary software as opposed to see about converting to mach 3 ?
    I've heard some have converted them but haven't found a lot of information on it yet
    are factory parts still easy to source?
    Dec 2013
    OK, that's a deal! I see no advantage at all in using the original software, in fact I don't think much of it, to restrictive and a PITA to work with. Converting to Mach3 would be a snap, I can't recommend a breakout board, but it would be a very easy conversion.
    Factory parts are available, but expensive, as is their tech support. Just about every part on that machine is an off-the-shelf item that is available from many vendors.
    thanks for all the info, i was worried that i rushed into a machine without knowing enough about it
    this makes it a little easier when i tell the wife "look what we bought today"
    I'm pretty sure she's going to see it in the garage or the loader taking it off the trailer
  7. #7
    Dec 2013
    My pleasure. Good luck with the wife
  8. #8
    wife is completely not impressed, her and one of her friends asked what does it do so i told them
    i could use it to build another one, does not think thats funny at all
    does anyone know where i can get a manual for this one?
  9. #9
    Sep 2006
    Quote Originally Posted by mikeyd895 View Post
    PM me with your email and I'll send you the 1999 SF Manual.
    Neal
  10. #10
    apparently your overloaded with messages already
    mike
  11. #11
    Sep 2006
    mike
    Sorry, Try again, I cleaned house! :-)
  12. #12
    Sep 2006
    Mike,
    I sent you 3 emails with the files I have for a SF. As for the electrical schematics, they can vary with each machine and original options installed, and are supplied to the original buyer at purchase. There was a time when MC would email them to you if you called support and have the SN, but maybe not any longer, you could try it.
    Neal
  13. #13
    thanks Neal
    i will try calling and see if i have any luck
    those manuals you sent are a real good start for me so far
    still cold here so be awhile before i move it here
