- need help Multicam 1000
I have a Multicam 1000 and am having issues with an apparent air seal leak inside the motor head. When the machine starts to operate, the air pressure at the line coming into the machine drops to 50 psi, the dust collector will not retract as designed, and the machine looses the ability to retract and reattach tooling. Any ideas out there on where to start to fix this problem?
Re: need help Multicam 1000
I think you answered your own question. If the seal in the rotary union in the spindle motor is leaking, then the only fix is to rebuild or replace the rotary union. It's time to tear it down and locate the problem. It could be a simple fix, or not. Depends on how bad things are torn up in there.
- You may not post replies
- You may not edit your posts
Forum Rules
