- Need Help!- Mulitcam 1000 series is jumping and getting off course
When we are cutting it will get to a corner of the cut and stop abruptly and get off course. Then it continues to cut and does the same thing at the opposite corner. Has anyone run into this?
Re: Mulitcam 1000 series is jumping and getting off course
Could corner overcut be turned on in the CAM program?
Can you run a old program to see if it runs correctly or not?
Trying to see is it a program issue or a machine problem
- You may not post replies
- You may not edit your posts
Forum Rules
