- Problem- Some troubles with Multicam remote control device
Re: Some troubles with Multicam remote control device
Have you checked to make sure that your machine is incoming transformer is tapped correctly? if the incoming power is tapped correctly check to make sure that your internal power supplies are sending the correct output voltage i.e. 5 volt power supply and your 24 volt power supply. Depending on the series machine it maybe two power supplies or a single one. Post a picture of the complete cabinet, because I think the MC series machine had one single power supply
I have ran into the problem of the power supply plug is no longer check the plug at the bottom wire # 128/138 and the outgoing wires up top. The plugs should take a little bit of a pull to remover them
- You may not post replies
- You may not edit your posts
Forum Rules
